Torque PIDs...Take 2
ShoBoat said:
sunwolf said:
pejohnson said:
I can't seem to get the following PIDs to work on the Torque Pro app on my phone.  Below is the data used.  Can any of you review and see if I missed something?  I would appreciate any help.
Long Name AWD PWM Modulation of rear
Short Name  AWD %
PID  22d128
Equation  A/256*100
Min Value  0
Max Value  100%
Units Header 761
Long Name    AWD Status on-off
Short Name  AWDStatus
PID  22191C
Equation  (256*A)+B
Min Value 0
Max Value  1
Units  (none)
Header  761
Long Name  LFTire Pressue  RFTire Pressure  RRTire Pressure  LRTire Pressure
Short Name  LF Pressure  RF Pressure  RR Pressure  LR Pressure
PID  222813  222814  222815  222816
Equation    (((256*A)+B)/3+22/3)*0.145 (same for all)
Min Value  0 (same for all)
Max Value  70 (same for all)
Units psi
Header  726 (same for all)
Also having trouble with tracking HP and Torque.  Lastly I somehow deleted all my custom PIDs and gauge layout on Torque Pro.  Which boost / vacuum equations/PIDs do I use?
Phil
AWD won't work on 13+
Confirmed not working, I will see if the PID is different for the 13+.
I have a file that might help you with that.....i will email it to you when I get home
In addition to very first post of this thread, is there a database that someone has that has all of the known and working PID mods that users have created? If not, I would be willing to attempt at making one. Using the info from very first post. But I would need someone to go through and verify them all before they go into file.
Would need all parameters and pix of editor and possibly the working gauge.
Think there's a pdf(?) File on the first post at very bottom.
Rich
FoMoCoSHO said:
ShoBoat said:
Short Name  AWD %
PID  22d128
Equation  A/256*100
Min Value  0
Max Value  100%
Units Header 761
PID  22191C
Equation  (256*A)+B
Min Value 0
Max Value  1
Units  (none)
Header  761
Units psi
Phil
Thanks FoMo, but I found the PID it is different for 13+ its 221e63 equation remains the same
FoMoCoSHO said:
Oh sweet, is the formula live?
Haven't fully tested it but in the garage it was at 3% and Forscan was reporting the same. So it should be. When I logged with Forscan in the past it was.
Rich
Awesome. Is it kept up to date with the latest and greatest?
Just tested the AWD PID seems to work as advertised. Interesting as the rear seems to jump to over 80% as soon as you step on the pedal from a dig. Even with light acceleration.
Rich
To the best of my ability yes it is - with one caveat.  I have a 2011 so the file is geared more toward the 2010 - 2012 years just because that is what I have so that is what I can test.  Several others have taken what I started and did a fantastic job figuring out some of the 2013+ PIDs.  The majority of the PIDs are common to all the years but anything with the AWD unit and anything in the Body Control Module (ie tire pressures) is different.  If someone is willing to pull together anything 2013 specific and send it to me I would happily post that file in the first post of this thread for reference.
That is what I see in my gauge....any provocation of the happy pedal moves power to the rear first.
Interesting. I don't see this in my 2011 -at least not as dramatically. It does send power rearward but only between 7 and 50% usually unless I stand on it from a stop.  I seldom see over 80%. I wonder if they tweaked the programing after 2013?
I had heard that they had made some changes. I would like to see the actual in a graph.
I will do some logging and report back.
I think 2013+ received the updated Gen 3 jtekt coupling.
There is some info in the awd area about this unit.
I emailed them for clarification but haven't heard back.
I'm pretty sure that in general the 13+SHO THE ECU & PCM was updated,and the encoding of the programming is totally different than the previous years. Z
