ajpturbo said:
JDW1 said:
ajpturbo said:
The log looked ok. Knock activity was good. I suspect that was a preliminary log. The throttle will open eventually but if it fluctuates don't worry about it. I suspect you also will be getting more boost as torrie dials the car in.
You don't have to stop the log as soon as you are done pulling....Let it go until it's easy for you to stop it...It's easy to find the section of WOT and zoom in on it. You can start it sooner also...Go ahead and let it pull 1st through whatever...The more data the better...You didn't really start until 4k in 3rd and barely got into 4th.
She is barely breaking a sweat yet
That's why I said janky log, i was in traffic, yea i'm that guy. When I was tuning I really only wanted a solid WOT in 4th from ~3-6k. It made it easier to see with out the shifting of gears and such. I'm sure Torrie sees it all. As far as boost goes, there are some spots where im over 90% WGD, those little turbos are about maxed there for sure.
Your wastegate duty was actually very low during ur wot....40-50 or so...for some reason the wastegates are held shut during cruise and coast....u were nowhere near maxing out those turbos...your boost was relatively low during ur pull...
U said u only wanted the pull from 3k to 6 k?...why?..the more data the Bette the tune
Hmm, I see what you mean now. Why in some spots do they look over worked, 90%+, then in others even with more boost look like they're on cruise control 60+%?
A good clean pull from say ~2500-6k in 4th would tell me everything i needed to know. All the extra is unnecessary clutter to me.
