- I've been chasing an annoying problem on my 2011 F150.
It generally makes plenty of power. Good stock, very good with SCT canned tunes, and great with custom tunes, but there is a persistent problem.
Scenario that will allow me to most reliably reproduce it:
- Cruising at 50-70 mph
- Slight incline
- 1,800-2,000 rpm
- Top gear (or similar rpm at reduced speed in lower gear)
- Light but increasing pressure on throttle
Response...- Transmission holds in gear, does not downshift with the light throttle
- Boost builds... but then starts to flutter. (boost, dump, boost, dump, cycling boost/dump about every half second).
- Light tunes will flutter between 10 and 15 psi, more aggressive tunes will flutter between 15-10 psi.
- Pattern will continue until I give it enough throttle to get it to kick-down to a lower gear and get the RPM's above 2,200 or so
- hardest to reproduce with stock tune, but I think mostly because it won't build much boost in that scenario.
- flutter noise sounds like wastegate is opening rather than BOV, but can't be sure.
- If I just boot it, the transmission kicks down a gear or two, boost builds without flutter, rocket ship takes off just fine, but light to medium throttle causes this extremely annoying behaviour
I can't figure out what is causing this...
- Is the wastegate being commanded to dump boost by the ECU, or a boost leak?
- I would suspect a boost leak, perhaps boost burping out of a hose clamp at higher pressures, but it seems to hold pressure fine when the RPM's aren't low...
- Should my transmission be kicking down at those light throttle pressures to keep the rpm's higher?
- Is it detecting knock and dumping wastegate pressure?
- Thoughts that this is related to my specific 'strategy code', as all aftermarket tunes just build upon the base strategy code?
- Any other thoughts as to what is causing this and possible remedies?
Other info:
- I believe the 2011's had integrated mechanical wastegates...
- The drivers side turbo was previously removed and reinstalled by Ford to install a block heater as part of a TSB, and given their track record, I don't trust they did everything perfectly. They say they've checked there work and everything is fine (though initially there were loose bolts, hose clamps, etc.)
- I believe there is a TSB for some 2011 EB's for sticking wastegate actuators, though this doesn't seem as much like sticking as being commanded to open.
Ideally, I'd just bring it to the dealer and have them diagnose and fix it, but I have no confidence in them. I've tried several of the dealers in my area and they all seem to be inept at any diagnosis or troubleshooting that doesn't involve check-engine-lights and specific 'pinpoint diagnosis' tests associated with the trouble codes. Plus it's hard to reproduce on city streets in an urban area, so it usually means scheduling a day to leave the car, dealing with a rental, then just getting it back with a 'could not reproduce' or 'normal operation' result and zero progress.
