High Command says the filter is built into the pump and not serviceable.ElvenSho said:I think i will have to do this if the fuel filter change does not fix it. Torrie wanta me to try that first since its the cheapest to do. Anyone know where exactly the fuel filter is located?SHOdded said:Check again for codes, like BigMac said. Then draw up a list of observations that you CAN present to the dealer like: uneven power, sound of "marbles" at part throttle, etc. And slip in a suggestion that maybe the engine's not getting enough fuel.
You do not have to revert to stock to read the codes. Codes will come up regardless. The SCT device should be able to scan the OBD port and present them to you, if any.
2013 is a better pump, you might want to see if you can upgrade to it.
