Here are my spark plugs for reference! I think me missing the SP542'S. LOL.  Z
Z keep us informed on the SP-542 equivalents you are running with Meth. There have been a couple people running meth they ended up fouling those cooler plugs.
Funny you mentioned that, I've been meaning to pull mine to inspect them and check the gap.
Meth cools the combustion chamber sooo.......
I think he is referring to the one step colder plugs fouling up!  Z  :)
Sooo.. long story short... Matt Robinson at GH offered to tune my LMS Firestorm setup... runs like a bat out of hell with his tune....
Trying for the track Friday or Saturday... we will see...
Driving manners are very well refined... very happy thus far.
I finally got my hpfp tuned right as well. SCT finally got their stuff together and running E35 holding 3k psi with dips of 2800psi first time trying E30 and barely on the first revision feels like my fine tuned meth tune. I'm currently not spraying any so hopefully once I get the ATPs on I can get the E tune and meth fine tuned at his dyno
Good deal, I had Matt also tune my 2010 meth. This tune is pushing more load so in theory it should be pushing more power. The track will be the ultimate test as I ran a 12.2 on my 2010. I ran a 12.799 with the E30 LMS tune... so we will see.
FWIW... we went 7 revision to get it right.. apparently my turbo's are very strong according to him.. kept going over demanded and having the throttle step in to prevent overboost conditions. I think every car has a little something different...
I also have the same strategy as he does on his 2016 so that made it easier lol.
Yea my car has been s*** to tune idk why I want to be a firm believer that it's bad turbos or wastegates cause ever since my first tune I kept hitting  100wgdc and always loosing boost and I've checked for leaks multiple times and fixed the 1 that found but none since. I'm sure matt will get my set up right once I get everything installed and go to his Dyno
Hopefully the turbos will fix that...  Matt is working with an engine builder out in my neck of the woods to get some custom cams and other fun stuff done.. once he gets done I am probably going the same route depending on results.. The rough estimate from LMS for their race block is high compared to other shops...
Yes I've talked to Matt about the LMS block he said he can get better pricing and with heads included. I'm looking forward to next year which is when I'm planning on going built motor.
You are going to be setting records at the pace you are going my man. Curious to see if the upgraded turbos fix your problem because I remember you always having issues with that.
On another note tires came in today... Truck/SUV tires that is. Figure the SHO is heavy enough to count ha! On top of that they are a decently "sticky" all season tire. 275/40r20 Hankook Ventus ST...
Ended up price matching them to an even lower $125 per tire and still getting the buy 3 get 1 free deal making them a grand total of.... $94 a tire. Only catch is I have to have them mounted and balanced there which at $60 for all 4 I will take that all day long. With them doing the work I can get my owner's advantage benefits on the whole lot giving me an extra $22 back. So basically paid... $468 all said and done once the wheels come in with the ability to use that twenty bucks or so on my next service. Getting the hook up with some good take off tire pressure sensors too. All around just getting mad stacks of deals. Loving it.
I Installed the NGK 97177 LTR6CI-8 Laser Iridium Plugs today and will see how they measure up!
They did all come pre-gapped @ 0.030 which was ideal and convenient....
Dielectric grease & antsieze was added on the plugs and boots for a peace of mind.  :)
I found the best price on www.rockauto.com for $8.35 ea
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,ignition,spark+plug,7212
https://www.rockauto.com/en/moreinfo.php?pk=6572356&cc=1503823&jsn=443
Laser Welded Tips
Trivalent Metal Plating
Longest Life Available
Thread Size: 14mm
Thread Pitch: 1.25mm
Seat Type: Tapered
Resistor: Yes
Resistor Value: 5K Ohm
Reach: 25mm (1")
Hex Size: 5/8" (16mm)
Terminal Type: Solid
Overall Height: ISO
Gap: .031" (0.8mm)
Center Electrode
Material: Iridium
Type: Fine Wire
Projection: Projected
Ground Electrode
Material: Platinum
Type: Standard
Specifications
Warranty: 1 Year
Torque Specs: Cast Iron: 10.8-18 lb. ft. Aluminum: 7.2-14.5 lb. ft.
Brand: NGK
Heat Range: 6
Longevity: 100k Miles
https://www.ngk.com/product.aspx?zpid=40565
