SHOdded said:Isn't the CSS supposed to come with a check valve?
It's routed like this, but by the way it was designed wouldn't the CSS let PCV gasses back into the cold side where it'll later turn into a liquid once cooled?
SHOdded said:Maybe you can just add another checkvalve at the airbox junction to prevent airflow into the airbox? IDK.
Mine is exactly like this, talked to the UPR guys and he said some dudes use a k&n mini pod as a vent istead of the intake.SM105K said:SHOdded said:Maybe you can just add another checkvalve at the airbox junction to prevent airflow into the airbox? IDK.
I really don't like that diagram. I would double check with the actual SHO diagram provided from UPR.
https://lib.store.yahoo.net/lib/yhst-37354654005614/5030-114.pdf
That is how it should be properly run. That is exactly how mine is run and it works amazing.
Here is my own thread on the CSS! Also another thread you might find beneficial. ZGofspar said:Mine is exactly like this, talked to the UPR guys and he said some dudes use a k&n mini pod as a vent istead of the intake.SM105K said:SHOdded said:Maybe you can just add another checkvalve at the airbox junction to prevent airflow into the airbox? IDK.
Might give it a try.
K&N vent Filter & Quick vent hose connector fitting and cap off the intake pipe port! Best of luck.Gofspar said:Mine is exactly like this, talked to the UPR guys and he said some dudes use a k&n mini pod as a vent istead of the intake.SM105K said:SHOdded said:Maybe you can just add another checkvalve at the airbox junction to prevent airflow into the airbox? IDK.
That is a-scootin'!Jordan said:Finally put together my crappy footage 11.16 run. Anyways here it is.
https://www.youtube.com/watch?v=VxJttrXHkKs&t
Upset that nobody can ever film worth a damn and get it in not 360p. At least the boards are mostly readable...
A trick you can do is to pull the wipers off the windshield while tuning, keeps them from dragging across the windshield!Quinid said:I also gave in and bought a used SCT X4 and bought an AJP 93 and E30 tune. Got a little scared during the tuning process. The tuner asked me to turn the Flex off at the beginning of the tune, so I did. As soon as I did, it started modifying with it off, then it turned back on and the wipers and the forward collision light turned on and stayed on during the tune. Now I just wait for the wife to get home from work to help me carry this 6L90 transmission for my LS swap to the garage so i don't tear up the interior during the test haha.
SHOdded said:Is the alternator working correctly? May want to see if you can enable dark mode via Forscan. gjkrisa had posted about it a while back. Also, the BMS needs some quiet time with the battery to relearn it.
