802SHO said:
I don't think anyone has done that before but it makes a lot of sense why it would be beneficial to have it pre each turbo, post intercooler and pre throttle body.  Covering every base and ensuring so serious cooling all around.  Water/meth or 100% meth?
100% meth. Can't wait to have GH tune it hotter. My LMS meth tune is fine with it.
And windows out these wittle turbos heat the air charge up quite and bit making them far less efficient and harder in the turbo. Cool the charge via wet compression at the source of the heat, should make the turbos life easier. And great intercooler and post ic meth is awesome, but does nothing for the temps and stress placed on the turbos, having to compress super hot air.
Sent from my PH-1 using Tapatalk
Installed new one step colder Motorcraft SP-542 spark plugs today and always use a dab of Anti-seize and dielectric grease for good measures..
The engine was warm to the touch but Somehow each and every plug was stuck on tight and would not budge,but fortunately used an old Canoe Aluminum paddle for torque which came in handy with little to minimal effort needed in removing those stubborn plugs and a must have for any DIY! Z
I have these wild fears of plugs breaking off in the head LOL.  I like to let penetrating oil do the work.  Do have to clean up after, not an easy job.
When push comes to shove! :D  BTW - In conjunction with spark plugs Condenser & GH- Intercooler install in progress! Z
Installed the UPR dual valve catch can with CSS...
What a PIA... the long line that goes to the intake and CSS was not long enough to really hide it... needed a few more inches...
We will see how it works...
Side note... the Fuel-It Bluetooth sensor connector is cheap AF... the pins are sliding out... so I’m gonna have to figure that one out... maybe a dab is silicon on the back side to hold them...
SHOdded said:
Better than snapping the HPFP bolts, I guess ...?
Yea... still having a small residual oil leak around the gasket... almost looks like a vapor leak as there is never any pooled or oil drips.. just staining...
So I checked the gasket and it looks ok. The only other options are either the stock spacer plater is slightly bent or the mounting pedestal is bent....
Installed my (2) 2006 Ford expedition trans coolers yesterday. Coolers are run in parallel and mounted Front of my Pusher fan and upgraded Intercooler. No A/C = No condenser. Disregard the $30 in amsoil aft on the ground. I decided to start/move the vehicle with the lines open. Smh
Did some work on my SHO this week:
Vinyl wrapped my flower wheels
Vinyl wrapped engine cover
Vinyl wrapped front fender SHO vent badge
Vinyl wrapped taillights in blackout vinyl
Vinyl wrapped headlights in smoke vinyl
Vinyl wrapped rear bumper reflectors
Sent from my SM-G965U using Tapatalk
I have the same UPR kit, you can tuck that line going over your radiator reservoir.  It's a pain but you have to disconnect there, and bring it in under the IC to TB pipe, I believe under or in between the compressor lines and route it to that area but in order to do that you need to disconnect all the lines and remove the canister as they will be in the way.  Basically need to route that line first, then the other lines, it all works better if you route all the lines first, connect to canister without the canister secured, secure canister to bracket last.  I also disconnected a fuel line as that appeared in my way with the dirty side.
When I get my SHO back I can show you if you have any more trouble with it.  I too was equally dismayed with my initial attempts to route rhe lines with no instructions.  You would think for the cost it would have some .....but apparently not lol!
The check valve that comes with it is good but they sell a high pressure check valve to "upgrade"  for another $50 if I recall.  The explanation I got from UPR is the check valve that comes with it works fine but what is your goal with the car?  "To track it and I don't drive it much.  It basically sits and then goes WOT, repeat."
You'll want the upgraded high pressure check valve as there is a potential under high pressure for some vapors in the canister to go through the check valve.....?  Isn't that the whole point of the catch can?  Why put an inferior check valve there?  I upgraded but not without asking why they didn't just make the kit with the high pressure check valves to begin with?  I don't like that stuff....make a great kit but keep one part of it upgradeable?  For something like this I think it should sold with everything included...and stop throwing in check valves that aren't high pressure.  Tiny rant over.
I really do like the kit.  I also found that the top of the oil cap would slide and not turn the base to remove it, if you need to remove your engine cover.  If I need to remove my engine cover I disconnect the oil cap line, pop the top out of its base, and use channel locks to gently secure the base and turn to remove it.
Let me know if you get it rerouted and what your initial impressions are.  You might as well try not to look in it for at least 3k.  What I got wasn't much at 3k but swishing it around in the canister I thought...well Im still glad this crap didn't make it through.
I thought I was good...youre not messing around!  What kind of vinyl is that?  I need to redo my trim around the windows.  I had carbon fiber vinyl there for a couple years but it dried out and started cracking last year.  It wasn't top quality vinyl.
A lot of hard work there man!  Looks great!
Thank you! It was bit of a challenge but nothing too crazy. Headlight and taillight tint was from Rvinyl and the vinyl I used for the wheels and badge was from vvivid, it was from their vvivid+ line which is vinyl specifically made for vehicle wraps.
802SHO said:
Thanks for the info I'm going to order some!  That black you used looks like it has metallic in it.  Looks great!
Ya it's a Black Metallic Sparkle, I wanted to do something a little different that just gloss or matte black like everyone else. I plan on doing the rest of the chrome trim on the car in same sparkle black vinyl. And thanks again!
Had an unplanned stop at the shop.... nails love tires.... good news is that the TPM is working just fine!
