geophb said:I cant comment on the rear turbo but I did the front one. simple hand tools. I pulled bumper, fans, rad/intercooler(comes out as one) then there was all kinds of room -> way easier than it sounds lol. But you may only need to pull fans. Don't over bend the flex joint on the downpipes cuz they will break.
New turbo did not have mounting brackets, updated design?. seems like alot of stress on a sheet metal manifold?
StealBlueSho said:geophb said:I cant comment on the rear turbo but I did the front one. simple hand tools. I pulled bumper, fans, rad/intercooler(comes out as one) then there was all kinds of room -> way easier than it sounds lol. But you may only need to pull fans. Don't over bend the flex joint on the downpipes cuz they will break.
Yes, they updated the design and the newer turbos don't have mouting brackets... the cast iron manifolds will hold them fine.
SHOdded said:Throwdown with Mike K. Now playing.
bpd1151 said:You know what they say when one ASSumes there BJ.
LOL. ****Snickers.
Love you dumpling.
SierraTBD said:First of all, thank you to everyone who replied :notworthy: I am new to the Ecoboost world coming from the diesel community. Belonging to DieselPlace.com I certainly appreciate the wisdom that exists in members of forums like this one.
Sounds like the rear does not need much more clearance to be removed.
This would be correct in an F150 application. Their manifolds are different from the transverse applications.StealBlueSho said:Ha! Just to throw some oil in the mix (can’t make dumplings without it) this article... which is fantastic also had LME calling out the manifolds as cast-iron....
https://www.fordnxt.com/tech-stories/engine/ecoboost-build-600-plus-horsepower-from-a-livernois-built-3-5-v6/
Wonder if that is your motor in the article?
StealBlueSho said:SierraTBD said:First of all, thank you to everyone who replied :notworthy: I am new to the Ecoboost world coming from the diesel community. Belonging to DieselPlace.com I certainly appreciate the wisdom that exists in members of forums like this one.
The front is reported as easy. The rear is a PIA from those that have done it from a creeper...
irondoor19 said:So we replaced both Front and Rear With ATPs (from a lift Tho)
and prior to doing the New Engine Swap........
and it was not that Tough, BUT we do not remember what all
has to come out (not much tho) SOO Doing it from the floor, YEA
it can be done, It is going to be a PITA... :angry1:
