2013 SHO Lamin-X Tints and LED conversion
I recommend using rubber electrical tape (stretchable) available at Lowes or Home Depot to tape up the adapter that  plugs into the OEM bulb socket . This stuff will NOT let any water in . I use it on all electrical wiring , car or home .
this thread is helping a lot.  I just contacted VLEDs about the special connector, we will see what they say when they reply.
Just so I am clear, this is all just plug and play right?  I am not splicing anything on my car no?
Yep! ...unless you want to use the "50% reduction" wire, but you won't.  Just read the directions and familiarize yourself with the pieces..... then start installing afterward.
You might want to call them... I did before I bought.  They are accessible and helpful....plus it may be quicker.
Your pictures helped a lot, and I'm not going to use that reduction wire.  I'm just waiting on those Ford-specific adapters to arrive and they're going in.  Did you ever figure out how to get to the side marker bulbs?
I was able to get my hand up there through the wheel well but I couldn't get it out.  I could get my fingers on it but not enough to turn it
Not yet....I am going to check the wheel wells one of these days...... maybe could be done "by feel" through there with car on jacks, wheels off, and wheel well liners removed.......Took a quick peak with the wheels on, but can't be sure it gives enough access.  If not the only solution is removing the bumper to do the side markers... Design Flaw!!
I took out the three bolts for the liners and stuck my hand up there with the wheel on.  I think if you had a long pair of needle nose you could get it out, but I don't envision you being able to get it back in.  The wheels and liners are not the problem, it's the other stuff in there, just too narrow to get your hand on the bulb.  I guess with the wheel out you could actually see it better to get it back in
4DR said in an earlier thread on this that if you  take off the wheels and  wheel well covers that the marker bulbs could be changed using needle  nose pliers and that it is a PITA.
Why I left them… Got the bulbs, but gonna have to be bored to tackle it for 2 itty bitty bulbs.
True!… I did use rubber splicing tape under the vinyl electrical tape.  :thumb:  You're right, should have mentioned that… best water seal short of painting them with silicon caulk. also seals out air so that you only have to deal with the slow electrolytic degradation of contacts rather than regular old oxidation and corrosion.
