FoMoCoSHO said:Jwill, Brian talks about making the mixture fatter, or needing less fuel to hit the ecms commanded afr. This is important because that means more fuel headroom and also better fuel economy if you care about that.
FoMoCoSHO said:I also noticed that my cat temps are higher (50 degrees ish) when I'm pounding on it.
If cat temps follow EGT, then this is also indicative that the mixture is indeed richer.
Hopefully someone smarter than I will chime in on EGT behavior vs cat temps.
Basically its just number of gallons added divided by 6. Then I just rounded up to the nearest quarter.J-Will said:Are you guys having trouble figuring out how to much ACES IV to add in during each fill up?
I don't have the product yet, I'm just planning its usage. And mixing seems like a hassle. Some product make you pour first, then fill up. This one seems a little more forgiving with the order.FoMoCoSHO said:Jwill are you trying to do it before or after? You can do both but I think after will be most accurate. Torque will give you a percentage which you can convert, but it is thrown off of the car isnt perfectly level.
J-Will said:I don't have the product yet, I'm just planning its usage. And mixing seems like a hassle. Some product make you pour first, then fill up. This one seems a little more forgiving with the order.FoMoCoSHO said:Jwill are you trying to do it before or after? You can do both but I think after will be most accurate. Torque will give you a percentage which you can convert, but it is thrown off of the car isnt perfectly level.
Sent from my Nexus 9 using Tapatalk
SHOdded said:True; with HEET I can add anytime
Heet is straight Methanol. Eventhough it is a dry gas, it is really corrosive!! ACES IV functions very well as a dry gas without any corrosion.
, but with 104+ I am supposed to add before fillup only. Of course having a saddle type fuel tank with AWD doesn't help matters much!
FoMoCoSHO said:Its not bad, I just wish the bottle had 1,.5, and .25 graduations.
The 16 oz bottle has a 1 oz cup, 1/2 oz and you can suppose the 1/4 oz rate. The 8 oz which you know is easier to carry in cramped quarters has the 1/2 oz and 1/4 oz increments. Some people choose to use the other side of the bottle and just do a tip and pour.
Brian, does the ACES need shaken like the other products?
I tend to agree with you after looking at the plugs when I changed them a few months back. This was after 4 tankfuls. Have you had it analyzed for confirmation though? They keep stating they DON'T use MMT in their formulation. Is there a "minimum" they can legally slide by with?BND 370 Hemi said:Remember that 104+ contains MMT with petroleum distillates as a vehicle.
SHOdded said:I tend to agree with you after looking at the plugs when I changed them a few months back. This was after 4 tankfuls. Have you had it analyzed for confirmation though? They keep stating they DON'T use MMT in their formulation. Is there a "minimum" they can legally slide by with?BND 370 Hemi said:Remember that 104+ contains MMT with petroleum distillates as a vehicle.
http://www.goldeagle.com/brands/104-faqs
No. 104+® brand products contain neither alcohol nor MMT® Fuel Additive* . MMT® is dangerous to spark plugs, catalytic converters, and OBD (on-board diagnostic) oxygen sensor systems. It is not recommended by vehicle manufacturers, and is considered an environmental hazard.
Could they possibly be using Ferrocene or another organometallic?
https://en.wikipedia.org/wiki/Ferrocene
FoMoCoSHO said:Brian,
I took the liberty to upload a profile pic for you.
I hope it is satisfactory.
If you would like something different, email it to me or call me sometime when we are both on and I will walk you through it.
