Dxlnt1 said:
I am glad that someone was able to scientifically qualify what I had been saying all along.
My experience with ACES is good. It is allowing me to run the 93 tune with only 91 fuel available. And the difference between those tunes is night and day.
On my truck, (2004 Yukon XL) I am seemingly picking up roughly 2 mpg using the ACES.
Mr. T, I do you notice your LOR and LTFT numbers all over the place? I have seen LOR go to -5 but KR stays maybe -2. The LTFT numbers are like a digital readout all over the place. My thinking is maybe the ECU cannot interpret the LOR with the ACES. But all other performance eta is good.
Do you mean -0.5 for LOR? It should never got to "-5" unless you are using a different formula? LOR isn't actually measured but inferred from knock so I don't see how ACES could directly impact your LOR value or prevent the ECU from adjusting it. If you are getting excessive knock the ECU will dial back the LOR...
FoMoCoSHO - I know we've discussed this before but I have actually been playing with LOR quite a bit lately and if I hit +4 or greater KR the car instantly adjust the LOR...Same is true for -4 KR (or if you are using ignition correction then switch those numbers around...) I believe you said your car had to see knock for some time before LOR was adjusted so I'm starting to think it is adjustable in the tune - which would hardly be surprising. Maybe LME is just taking LOR down right away if it sees knock...
