Aeroforce Gauges for your Ecoboost vehicle
I just ordered mine!
I cannot wait to get the gauge - I also ordered some of the angled autometer gauge holders off ebay for $14.95 for three of them.  (See Todd's post number 74 on page 5)    I figured an extra few of them were good (even though I only need one) in case I decided to file them for different areas to see what I liked best.  I don't know if they will be a temporary or permanent solution until I see the whole thing "installed" in person.
Guys if you need please use my site to order, the profits I am directly sinking back into this site, I'm currently paying a few thousand dollars for the update. Every little bit helps a TON.
http://shop.ecoboostpowerparts.com/Aeroforce-Interceptor-Gauge-Ford-EcoBoost-All-AeoforceCN1.htm
I ordered mine from ecoboostpowerparts and got them super fast.  Never had a problem ordering the few parts I did from Mike.  I plan on ordering the SHO "noisemaker" eliminator pipe this weekend.
I  2nd that ... on the up n up  for sure .
So far PPE catless down pipes from him and RX evac catch can setup w/ clean side .
And he went out of his way to help BigMac's  sale to me with new clamps and Tial BOV for My Hot Pipe Kit ..
TSS said:
Sorry one more question.  I know the gauge can display boost with our vehicles, has anybody confirmed that MPH can be displayed too?  Todd, the website indictaes "may" be able to display depending on vehicle - or something like that.  I am a hair away from ordering if I know I can have boost number on top and MPH on the bottom......
MPH can be displayed so you can display boost and mph at the same time.
Todd
FoMoCoSHO said:
Probably a dumb ?, but they do fit in Crash's pod correct?
Yes it will and he can drill 1-3 52mm (2 1/16th") holes or a little larger or a different shape or whatever you want and do the faceplate in black or the woven metal which is identical to OEM... I have his pod, and happy to have one the fit and finish are stellar!
PM him for more if you're interested as I think supplies may be limited.
I've had one sitting here for a while.
Excellent! ... on of the privileged few!  :beer2:
Installed my Aeroforce gauges in Crashes gauge pod this past weekend.  They fit great, look great and work great.  I'll get some pictures up tomorrow.  Still playing with the setting and what PIDs to display.
Looks like platform 4 has all the right PIDs for our cars.  For trans temp it's trans temp 3. I'll run through some others to see what ones works and don't.
Looks like platform 4 has all the right PIDs for our cars.  For trans temp it's trans temp 4. I'll run through some others to see what ones works and don't.
Cool!  Definitely wanna' see the pics!...  :popcorn:
I got the gauge yesterday!  Very cool, but I have a question re: the Boost Function (2010 Lincoln MKS 3.5 Ecoboost).
On the video that is linked in post #1, page #1 , at about 3:00 to 3:25 into the clip or so there appears to be a boost function that displays negative numbers and  THEN there is another boost function called desired boost or command boost that only displays 0 and positive numbers.  In other words, it does not display any negative numbers.  I can get the regular boost function (with negative numbers)  but would love to find the other feature that only displays 0 or positive numbers….that way…under normal use without turbo engaged, the numbers are not constantly changing – it would just indicate 0.  I took a look at the linked video last night, and that function is definitely there, but for some reason I cannot find it on my unit.  Thanks for your help!
Commanded boost isn't what you're doing it's what the motor is being told to do, not really useful for you.
The negative numbers are vacuum, which is what your car runs on when the throttle isn't engaged.
Here is mine.  the display is absolutely clear in person. For some reason I just could not get a picture of it. However, at least it shows the location. No wires at all are visible. I ran them Down between the clear plastic in the gauge cluster and the  black plastic that meets the clear plastic.
FoMoCoSHO said:
Any glare issues?
No glare issues.  Looks awesome at night, a bit hard to see during the day with the black background and blue digits.  Haven't been in the car with the sun out and the blue background and black digits.
