D
Guest
That ought to be interesting. Good Luck!
watt-maker said:Time to order some good quality silicon hoses and fab some aluminum/SS/or even just some painted steel tubing and ditch the plastic setup. I've seen a few 6.0L Ford diesels blow the factory plastic pipe.
EcoBrick Bob said:watt-maker said:Time to order some good quality silicon hoses and fab some aluminum/SS/or even just some painted steel tubing and ditch the plastic setup. I've seen a few 6.0L Ford diesels blow the factory plastic pipe.
Would there be a heat sink issue with metal tubing? Would larger pipes from turbo to intercooler be of any benefit?
4DRHTRD said:I'm heading down to the shop to make a new tube today, hopefully they have some tubing small enough to connect to the witty bitty baby turbos.crash712us said:Looks like a fresh tear, could it be stock tubing isn't enough?![]()
I think 110+ degrees out doesn't help, probably work where it's not so hot, I don't know what the Livernois big turbo guys have done to accommodate their higher boost.
darreli said:Hey Mike, as Crash stated, I had a similar issue. Mine appeared to be a little more dry rottted than yours but still similar in appearance. I ended up replacing it with a silicone hose.
FaSSt9602 said:EcoBrick Bob said:watt-maker said:Time to order some good quality silicon hoses and fab some aluminum/SS/or even just some painted steel tubing and ditch the plastic setup. I've seen a few 6.0L Ford diesels blow the factory plastic pipe.
Not complete apples to apples, but on my diesel truck I noticed (as many others have) an increase in lag when increasing the charge pipes from the stock 3" to 3.5" like that of the Banks intercooler on my truck. Many will run the larger Banks intercooler with reducers to keep the charge pipe diameter.
Sent from my SCH-I535 using Tapatalk 2
EcoBrick Bob said:For those who wonder why the 3.7 version isn't turbo'd, he said Ford tried that, and the stroke length caused failures as early as 100 mi.
Longer stroke puts the rods in a bad position for boost and they break, long rod motors and boost usually don't get along.SHOdded said:EcoBrick Bob said:For those who wonder why the 3.7 version isn't turbo'd, he said Ford tried that, and the stroke length caused failures as early as 100 mi.
So the 3.7 is a bored AND stroked version of the 3.5? I thought the bore increase was the reason for the failures (walls too thin). Forgive the noob Q, but how does the stroke increase translate into a failure?
