That I do sir.ajpturbo said:Do u live in canadia? Then maybe...otherwise only the current gtr and the r32 from 1991 and older can be imported legally to the states...the current r35 is produced for North America so no need to import...all others not in that range can be seized
ajpturbo said:Read through your old stuff....u sure someone didn't put high flow cats or did some exhaust work?...and u have a 010' model year...id probably change those front o2's...they can cause drivability issues if the ecu isn't seeing the correct lambda or afr for a given situation...u are now showing pending primary o2 dtc so that is a place to start...maybe a rat chewed the wires..highflow cats can rattle when u get on it
To my understanding I got a new one with the short block. On work order there is a timing chain.FoMoCoSHO said:Did the D-ship check the timing chain tensioner?
The tensioner and guides should be a different part #RagingPenguin said:To my understanding I got a new one with the short block. On work order there is a timing chain.FoMoCoSHO said:Did the D-ship check the timing chain tensioner?
Ordering a new O2 right now.
