TopherSho said:AJP turbo said:It comes up with those numbers based look up tables and algorithms in the Ecu. The OEM has done the leg work with mapping out the power output at various loads. The values you see in livelink may vary from real world due to different mods to the car.
It's pretty complicated though. But it has to know the torque values to knock how much boost to command...It's a great system but their are flaws and it's the culprit for limp mode and the wrench light often.
Hey AJP, do you know if there is any hazard of running a datalog from a config file that might not match your firmware? I found 3 dmjk profiles in LiveLink and configed a datalog profile for some of the DMRs discussed and a few more. But was concerned about causing issues with the ECU trying to read values that may be wrong from the wrong cells in memory ..
thoughts ?
No hazards.... they may just not read anything.
