FORScan?
ZSHO said:
AFAIK the only way to add Navigation,instead of compass on the right side of the instrument cluster is through IDS Software and then you will need a Vin-specific AB File in order to program the Data for the IPC.IIRC
Here's mine below and has been working flawless for almost two years now.  Z
With forscan you can do just about everything you can do with IDs there was info in the fiesta forum that added nav I can't find it now as I didn't want to add nav but wish that the camera would pick up the speed limit signs.
Or I was wishing is the camera only used for auto hi beams?
If I find it I need to add to list of things can do.
Gjkrisa said:
Ford GT!
https://youtu.be/kBVsGlfX9lw
Nice!
I would love to have that but with SHO to replace the GT and then keep the Ford Performance.  Has anyone found a way to load custom flash screens versus just enabling what is already apparently loaded in the unit?
No have not read anything on that but should be in the works since we finally got sync update file someone just needs tear it apart.
I agree would be nice to have just Ford performance
Maybe one of the 350 ones do that. Use to read there was one but I was confused what was changing so thats when I just started doing random things in that and found the Lincoln so I kept with that till I found f150 updated the spreadsheet.
lamrith said:
Gjkrisa said:
Ford GT!
Nice!
The visual design variant is how to change theme.
I was able to get lincoln theme but gt theme doesn't want to work :(
Sweet.  Ordered my OBD2 MX lastnight, will get FORScan loaded on laptop so I am ready to mess my car up good.  :-p
Plan to mess with splash screen and add the AWD readout.
Have to start diggin thru those Fiesta/F150 threads for any other goodies to mess with.
Thanks GJ!
Thanks GJ!
Cool go thru this and get your code when it comes in think the code only last 8 days now but generating a new is easy when it expires it just sucks when it's  a been a bit and forget to renew it and  have to generate a new one
http://forscan.org/forum/viewtopic.php?f=5&t=836
Thanks GJ!
8 days?  I got mine last night, and it's 8 weeks
Thanks GJ!
Thank you I didn't remember
Another thing I'd love to find is my rear doors don't unlock automatically untill I turn the vehicle off.
I wish all doors would unlock when I go-to park.
Might work with an OTG adapter for Android devices.  Not sure what to do for iOS tho.  I like cabled if I can swing it.
Getting the doors to unlock shifting to park seems to be proving elusive, hopefully someone will crack it soon. Do you have global close enabled? I've got it enabled but it doesn't work, open works fine.
I'm sure there are things you can change in sync 2 but don't know what they are people have added reverse camera and nav just editing the sync 2 I believe
http://forscan.org/forum/viewtopic.php?f=6&t=3898
Gjkrisa said:
AWD distribution driver gauge
ipc
720-01-02 8AFC-4CF0-3F2B asbuilt
720-01-02 BAFC-4CF0-3F5B
Well I got the AWD to show, but I noticed that it only shows me fuel level and not the dual fuel/rpm bar gauge like yours does.  All good regardless.  Driving in S mode using the paddles has been fun and really changes the feel of the car.  It will be nice to see how the awd is kicking in and when as I goof around.
