FORScan?
Might be because I've had the temp gauge option on or recently used the paddles before turning the option on or maybe just some other programming different. I can try to take a picture of my settings to see what else is different.
Turn off amp and have clean preout from radio from fusion forum
http://www.2gfusions.net/showthread.php?tid=3704
Ford fusion write up for FORScan
http://www.2gfusions.net/showthread.php?tid=4573
Never mind, I found a discussion on the forscan forum and it appears enabling global close does nothing on the taurus. Anyone messed with secure idle? On 726-42-01 I had x1xx xxxx xxxx, which should be enabled but the shift lever does not lock when the fob is out of the car.  I switched the 1 to 0 for the heck of it and got service advancedtrac and the ABS light on, guess I could go do a burnout or something..
I think the global open opens all doors when driver opens their door and car is off...
If that's as far as we can get to global open I don't know what Ford was thinking?
trying to be a pioneer in passenger safety?
What if there was a roll over does it still act the same way?
Global open rolls the windows down when you hold the unlock button on the fob down, global close should roll them up when you hold the lock button down. I enabled global close, but apparently it does nothing on some models including Taurus. Global open is awesome! If it starts raining and I've left the windows up, I can just roll them down with the fob and get a good washin' on the interior. (Sarcasm)
So messing around a bit in FORSCan I decided to look into disabling the factory eq processing. Strangely enough the 727-01-02 is set to 0031 on my ACM... and other SHO vin that I have looked up? Anybody run across this?
The 00xx is the correct setting to disable it.
Can't find the post but person asking about the tach and fuel on awd guage
Yeah I have global turned on even went and turned the driver setting on and didn't work but good thing since I still have the window shades for the kid down
AHh hhaa!!  Thanks I recall seeing that before and I think I turned it off as I was using the RPM display all the time.
Thanks bud!!
Does anyone know what the window safety  sensor name is?
Global open does not work because we don't have the safety sensor.
Are you talking about the Bounce-Back feature? If so, I thought any window with the auto up feature had to have bounce-back for safety.
Yes I'm curious if you can see the module in forscan so you would know if you can enable the feature and have it work or not
Global open on the front 2 windows works, its global close that we can't seem to get working on the SHO. Which is weird as they do have auto up on the door switch. Even if you try to enable it in FORScan it still won't work. I have tried it.
Hmm I can't seem to get open to work just double click unlock and hold unlock right?
Yes and it must be enabled in the left cluster
Yea I did that still no go but I might of had timing off or something I'll try again later
My car is a '13 PP.  I just checked and made sure it was "on" in left dash settings.  I have not altered anything for the windows using FORScan.
click-clickhold worked for me.  It was a loong hold on the second click, 3-5 seconds?  I also did a slow sequence.  Not clickclick...  more like click and clickhold.  When I tried it fast it dis not work.
This one seems to work just pressing unlock and holding it a few seconds. They start rolling down when I let off the button.
