Half-Fast said:Remote close isn't an option it appears
There's the option to turn it on, it just appears to not do anything on the Taurus platform. If that's what you meant, my bad.
No I haven't seen that yet. Thank you.Izzybird said:I assume you've already seen this Gjkrisa?
http://forscan.org/forum/download/file.php?id=1563
I thought of that too need to find a vehicle that has it. Although it was not on fordpi.com so I'm guessing it doesn't work.ShoBoat said:Hmm I wonder if TPMS can be enabled on the left stack on a 2013 SHO?
Doesn't the new Explorer have it?Gjkrisa said:I thought of that too need to find a vehicle that has it. Although it was not on fordpi.com so I'm guessing it doesn't work.ShoBoat said:Hmm I wonder if TPMS can be enabled on the left stack on a 2013 SHO?
Still worth a look into though.
Cool I haven't been inside any newer Ford's just mine and my dad's 2012 V10 f250ShoBoat said:Doesn't the new Explorer have it?Gjkrisa said:I thought of that too need to find a vehicle that has it. Although it was not on fordpi.com so I'm guessing it doesn't work.ShoBoat said:Hmm I wonder if TPMS can be enabled on the left stack on a 2013 SHO?
Thank I will try to look into it using the adb compare tool.ShoBoat said:http://www.explorerforum.com/forums/index.php?threads/tire-pressure-sensor-fault-under-1k-miles.433028/
Here is how it looks on the explorer, I know that mine for example has the capability as we found the PIDs for it and I can display it on the torque app. Wondering if it can be enabled on the SHO
Thanks that's the possible tedius part.ShoBoat said:726-08-01x1xxxxxxxxxxTire Pressure Monitor enabledobserved through testing on 1-5-17
726-08-01x0xxxxxxxxxxTire Pressure Monitor disabled
This was from the F-150 forum.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=0
We do have that address mine is set to BCM 726-08-01 0200 38
Gjkrisa said:Thanks that's the possible tedius part.ShoBoat said:726-08-01x1xxxxxxxxxxTire Pressure Monitor enabledobserved through testing on 1-5-17
now just need to see what bit although an sync 2.2 seems like flipping most bits are the same as f150 but I feel this one should be different.
I would first try 1 then 0
Nice!ShoBoat said:726-08-01 0200 38
from a 2017 SHO
726-08-01 0101 0000 0038
from a 2017 Explorer sport
Damn it, oh well I guys I'll keep looking thanksGjkrisa said:No go I've tried even 202 and says failed
