Fuel Pump Module Recall
SHOdded said:
From all accounts, it might make a noticeable improvement, good luck!
Okay seriously, EVERYONE needs to go do this.  It got rid of the cold start throttle surge I had.  Also, dare I say this without a lot of miles but it may have rid the car of the annoying low throttle surge I was having!!!
It sounds like they reflashed your car,any pic's of the work order? Thanks & enjoy.  Z
I don't believe they did...Or he is driving around stock.
If any member needs the FDM Harness/connector Rock auto has a great deal and receive an additional 5% Discount using code: 1A0ACE283964FE
    Expires: March 16, 2017.  Z  39.79
http://www.rockauto.com/en/moreinfo.php?pk=508155&cc=1503823&jsn=596
http://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,electrical-connector,fuel+pump+drive+module+connector,15715
I'm already running the most current strategy you can get for a 13'.
I just received a recall letter from my dealer to make an appointment for the replace of the fuel pump control module. Do I have to return my tune to stock ,  will they reflash the computer when they replace the fuel pump module ??  Thanks
The dealer sometimes will need to update(reflash)your PCM for this recall IIRC or for any other matter when you least expect it so would revert back to stock tune prior to the dealer visit just to be on the safe side of things.  Z
I actually just installed this in a buddy's 2013 mks a couple weeks ago, but not the ecoboost version, so it wasn't part of the recall.  He bought the part from a ford / lincoln dealership for like $60.  Parts guy told him they've been going through a lot of these modules lately.
The car was randomly stalling out on him and throwing lean colds.  Swapped the new module in and he's been good ever since.
My car still running strong ,I haven't have any issues with the module or throwing codes at all . I been having my car since 2015 and no issues at all ! :)
Mine was tuned when the module went and they re-flashed it after they did the work. I had no issues from that, outside of needing a new tune from Livernois.
Does anyone know where this is physically located in a 2014 SHO? I checked in the trunk and didn't see anything.  I have a ton of car audio gear in the car so I'm going to have to rip some stuff apart, but I found some pics of it being near the rear wheel wells, I checked both sides and didn't see anything.  Could it be in the little area right behind the back seats in the middle? There is some module there I had to cut out some room on my amp rack to fit over. Of course I'll need to pull my amp rack to get to it ;_;
Hawkeye is correct just put down the (passenger side) back seat and its located on top of the shock mount right behind the liner which is held down by two plastic Rivet's.  Z
I found using a small flat head screw driver and a pair of needle nose pliers to be ideal. Z
Well that explains it, I now see the padding there, I was looking in the trunk side behind the liner and there was nothing there. I just went out and pulled the liner back on the passenger compartment side and saw it right there.  Thanks!
