Its from my understanding that the correct part number for the FLEX/MKT would be AA8Z-9D370B as per recall. Z66 Galaxie said:Another part number is popping up on some of the Flex module replacements. aa8a-9d412-ca
ZSHO said:Its from my understanding that the correct part number for the FLEX/MKT would be AA8Z-9D370B as per recall. Z66 Galaxie said:Another part number is popping up on some of the Flex module replacements. aa8a-9d412-ca
SHOdded said:Replacement for the MKS also? I see the AA part number on EBay66 Galaxie said:Another part number is popping up on some of the Flex module replacements. aa8a-9d412-ca
Donor Vehicle Information
This item taken off of:
2012 Lincoln MKS
4 Door Sedan AWD
Engine: 3.5L V6 DOHC 24V
Gas Injected Turbocharged
Twin-Turbo W/ECOBOOST
57k miles
Transmission: 6-Speed Automatic
Exterior Color: Black, Code: UH
Interior Color: Black, Code: FW
Manufactured in USA By Ford Motor Co.
Production Date: 12/2011
VIN: 1LNHL9FT4CG805393
I guess a lot can happen in 3 weeks,especially with the Michigan winter ....better be safe than sorry and order the part and hopefully get reimbursed later especially it being relatively cheap to purchase .Zmetroplex said:ZSHO said:Its from my understanding that the correct part number for the FLEX/MKT would be AA8Z-9D370B as per recall. Z66 Galaxie said:Another part number is popping up on some of the Flex module replacements. aa8a-9d412-ca
The number you see laser'd onto the part is the engineering part number, and your relay is a -EA engineering number for the -D part number.
Based on the recall flowchart you posted, the AA8Z-9D370-B is OK if the supplier code matches, otherwise it has to be replaced. AA8Z-9D370-D would be good to go and from your receipt, it looks to be the part used by your dealer for your fix.
My dealer says they will see me 3 weeks from now to perform the recalls.
Why would you say that? Zmetroplex said:I ordered the AA8Z-9D370-D from Tasca, hopefully it works since that is what you're using. I'm also hoping it doesn't reduce the power output and cause my car to run slower in the 1/4 mile
CroR1 said:I had mine done the other day, I thought on the invoice the last letter was A, on the part number. I would have to double check... Bit disappointed in the dealer's service regarding factory warranty, so I will not be purchasing the extended warranty.
