Dealer replaced long block under warranty. my car was manufactured in 2012. has to be a new one.derfdog15 said:Did you put in an assembled longblock? If so, I would bet the HPFP is an accessory that was included, especially if it was a used motor.
polskifacet said:I have to give LMS a chance to analyze the logs and mention that StealBlueSho had the same issue with a SCT programmer and a different tune which was ultimately fixed by a tune change. I hope this gets solved once and for all guys, I am absolutely willing to drive the 4 hours to LMS and let them have at it. Otherwise I'll setup a gofundme for a AJP tune in the end LMAO!
polskifacet said:Logging with SCT. mycal doesnt have the capability. They will look at them, I can't do any better without getting an invite to their shop.
StealBlueSho said:polskifacet said:Logging with SCT. mycal doesnt have the capability. They will look at them, I can't do any better without getting an invite to their shop.
Glad they changed their stance on SCT logging... I would be curious if there are certain parameters they are having you record?
Historically they have said the SCT datalogging is not accurate and people don't look at the right parameters in order to make an informed decision...
I can certainly try to request a personal invite for ya and hopefully get her dialed in and while your there you can put her on the Dyno. LMK. Zpolskifacet said:Logging with SCT. mycal doesnt have the capability. They will look at them, I can't do any better without getting an invite to their shop.
30 ms readings MOST of the time with Forscan Lite and OBDLink MX BT, monitoring approx 65 PIDs.derfdog15 said:I can understand saying that about parameters that are logged, depending on the issue. However, the SCT logs are extremely accurate,and have an amazing resolution! I work with engine testing and dataloging for a living and the best resolution we can get is 20ms, and only ~20 parameters at that speed. Granted you can get to ~25 if that is all you log, and can log a whole bunch more parameters at 1500ms or so in a different data mode (less accurate and more prone to drop out).
But the PID read at 1 ms update rate that SCT has is pretty amazing.
