2017 Escape/MKC/Continental – Battery Discharge – With Or Without Repetitive Cycling Compact Disc (CD) Ejecting Noise – Built On Or Before 23-Dec-2016
Some 2017 MKC and Continental with all audio systems and 2017 Escape with Sony audio systems built on or before 23-Dec-2016 may exhibit a discharged battery.
A repetitive cycling noise similar to a CD ejecting noise may also be present.
If excessive battery drain is present and eliminated with the radio battery power fuse removed, reprogram the audio control module (ACM) to the latest calibration using the Integrated Diagnostic System (IDS) release 103.05A or higher.
Make sure you are connected to the internet when entering module programming to obtain the latest updates.
Calibration files may also be obtained at www.motorcraftservice.com.
Module Reprogramming & Initialization
Software necessary to program electronic modules to the latest calibration level, perform module initialization (PATS), and set Programmable Parameters on Ford, Lincoln and Mercury vehicles.
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
Latest Calibration Information
Module Build Data (As-Built)
Use VIN to obtain As-Built data
