Ford Expedition & Lincoln Navigator
Moderator
Staff member
2015-2016 Expedition/Navigator – Blower Motor Fluctuation When Coolant Temperature Is Below 122F (50C)
Some 2015-2016 Expedition/Navigator vehicles may exhibit noticeable blower motor speed fluctuations when the engine is cold or as the engine is warming up to normal operating temperature.
This is most likely to occur when the coolant temperature is below 122 degrees Fahrenheit (50 degrees Celsius.)
Reprogram the Heating, Ventilation, Air Conditioning Module (HVAC) to the latest calibration using IDS release 105.01 or higher.
Make sure you are connected to the internet when entering module programming to obtain the latest updates.
Calibration files may also be obtained at www.motorcraftservice.com.
FORD RECALLS 2018 EXPEDITION AND LINCOLN NAVIGATOR SUVS
January 27, 2018 — Ford is recalling 363 model year 2018 Ford Expedition and Lincoln Navigator SUVs with second-row power windows that may not automatically reverse if fingers or other objects are pinched by the windows.
According to federal safety standards for power windows, the windows should immediately reverse to prevent injuries.
The automaker blames certain second-row window control modules that were manufactured with incorrect electronic components, but Ford is not aware of any accidents or injuries associated with the window problems.
The 2018 Ford Expeditions were built November 27, 2017, to December 9, 2017, and the 2018 Lincoln Navigators were built November 27, 2017, to December 7, 2017.
About 361 of the SUVs are in the U.S. and two are in Canada.
Ford and Lincoln dealers will replace the second-row window electronic control modules.
The recall is expected to begin February 5, 2018. Owners of 2018 Ford Expedition and Lincoln Navigator SUVs may contact Ford at 866-436-7332.
The Ford reference number for this recall is 18C01..  Z
https://www.carcomplaints.com/news/2018/ford-recalls-2018-expedition-lincoln-navigator.shtml
SSM 47126 – 2018 Expedition/Navigator – Lack Of A/C Cooling – No Diagnostic Trouble Codes (DTCs) – Built On 16-Dec-2017 And Through 6-Feb-2018
Some 2018 Expedition/Navigator vehicles built on 16-Dec-2017 and through 6-Feb-2018 may exhibit a lack of A/C cooling with no associated DTCs.
Do not install an A/C machine or A/C pressure gauges for any reason.
These vehicles may contain an R1234YF refrigerant that is contaminated and may damage a standard R1234YF recovery machine if installed.
Do not attempt any repairs associated with A/C recovery on these vehicles.
Engineering is investigating, monitor OASIS for updates.
SSM 47403 – 2017-2018 Continental, 2018 Navigator – Outside Front Seat Bolster Support Bracket Available For Service
Some 2017-2018 Continental and 2018 Navigator vehicles may exhibit an outside front seat bolster support bracket that is broken or cracked.
The outside front seat bolster support bracket is now available as a separate service part.
Base part number 9960328. When ordering, please refer to the parts catalog for the VIN specific application.
APPLICABLE VEHICLES
2017 – 2018 CAR: PL D544N CONTINENTAL
2018 TRUCK: B9 U554N NAVIGATOR
uly 20, 2018
TO: All U.S. Ford and Lincoln Dealers
SUBJECT: Customer Satisfaction Program 18N01
Certain 2018 Model Year Expedition and Navigator Vehicles Equipped With R-1234yf Refrigerant
Special R-1234yf Refrigerant Service Information
PROGRAM TERMS
This is a one-time repair program and DOES NOT apply to vehicles outside of New Vehicle Limited Warranty.  Coverage is automatically transferred to subsequent owners.
AFFECTED VEHICLES
Vehicle Model Year Assembly Plant Build Dates
Expedition 2018 Kentucky Truck January 2, 2018 through February 6, 2018
Navigator 2018 Kentucky Truck January 2, 2018 through February 6, 2018
Affected vehicles are identified in OASIS.
REASON FOR THIS PROGRAM
This program provides special service instructions, loaner equipment, and rental assistance to expedite the repair of affected vehicles equipped with R-1234yf A/C refrigerant, which may be contaminated.
NOTE: DO NOT connect an A/C recovery machine or pressure gauges to the vehicle unless directed by this article, as damage to the equipment may result.
SERVICE ACTION
If a vehicle equipped with R-1234yf refrigerant, with a build date between January 2, 2018 and February 6, 2018, exhibits a lack of A/C cooling with no associated DTCs, or requires recovery of R-1234yf A/C refrigerant to complete a service repair, dealers are to obtain the equipment from Ford Motor Company necessary to evacuate the A/C system.  Once the refrigerant has been evacuated, dealers will replace the A/C components identified in this bulletin and recharge the system following the instructions in Attachment III.  This includes, but is not limited to damage caused by collision or other.  This service must be performed at no charge to the vehicle owner.
NOTE:  To obtain the loaner equipment, dealers are to submit a VIN-specific contact via the Special Service Support Center (SSSC) web contact site.  Follow the on-line instructions and complete the bailment agreement.  The SSSC web contact site can be accessed through the Professional Technician Society (PTS) website using the SSSC link listed at the bottom of the OASIS VIN report screen or listed under the SSSC tab.
OWNER NOTIFICATION MAILING SCHEDULE
Owner Letters will not be mailed for this program.
Attachment I: Administrative Information
Attachment II: Labor Allowances and Parts Ordering Information
Attachment III: Technical Information
Attachment IV: Dealer Bailment Agreement
Attachment V: Contaminated Refrigerant Recovery Loaner Equipment User Instructions
QUESTIONS & ASSISTANCE
For questions and assistance, contact the Special Service Support Center (SSSC) via the SSSC Web Contact Site.  The SSSC Web Contact Site can be accessed through the Professional Technician Society (PTS) website using the SSSC link listed at the bottom of the OASIS VIN report screen or listed under the SSSC tab.
Sincerely,
David J. Johnson
June 21, 2018
SUBJECT: NEW VEHICLE DEMONSTRATION / DELIVERY HOLD –  Safety Recall 18S17
Certain 2018 Model Year F-150, Expedition, Navigator Vehicles Equipped with a 3.5L GTDI Engine
High-Pressure Fuel Pump Replacement
REF: NEW VEHICLE DEMONSTRATION / DELIVERY HOLD – Advance Notice – Safety Recall 18S17
Dated: June 12, 2018
AFFECTED VEHICLES
F-150 2018 Dearborn Truck March 14, 2018 through April 24, 2018
F-150 2018 Kansas City March 20, 2018 through April 17, 2018
Expedition 2018 Kentucky Truck March 14, 2018 through April 12, 2018
Navigator 2018 Kentucky Truck February 20, 2018 through May 6, 2018
Affected vehicles are identified in OASIS and FSA VIN Lists.
REASON FOR THIS SAFETY RECALL
In the affected vehicles, the high-pressure fuel pump flange weld may crack, allowing the highpressure fuel pump to move while the engine is running.  Movement of the high-pressure fuel pump can cause the fuel tubes to leak.  A fuel leak in the presence of an ignition source may increase the risk of a fire.
SERVICE ACTION
Before demonstrating or delivering any new in-stock vehicles involved in this recall, dealers are to replace the high-pressure fuel pump.  This service must be performed on all affected vehicles at no charge to the vehicle owner.  Parts to repair this condition are currently not available in sufficient quantities to service all of the affected vehicles.  Until parts are available to repair all vehicles, dealers should only repair unsold vehicles with a signed sales contract.
Owner letters are expected to be mailed the week of July 16, 2018.  Dealers should repair any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter.
PLEASE NOTE:
Federal law requires dealers to complete this recall service before a new vehicle is delivered to the buyer or lessee.  Violation of this requirement by a dealer could result in a civil penalty of up to $21,000 per vehicle.  Correct all vehicles in your new vehicle inventory before delivery.
Owner Notification Letter
Sincerely,
David J. Johnson
SSM 47385 – 2018 Expedition/Navigator – 3.5L EcoBoost – Oil Pan Leak – Built On Or Before 26-Feb-2018
Some 2018 Expedition/Navigator vehicles built on or before 26-Feb-2018 may exhibit an oil leak from the oil pan RTV seal.
Replace the oil pan following the procedure in Workshop Manual (WSM) Section, 303-01.
After removing the oil pan, it is suggested to allow the crankcase to drain overnight to minimize the chance of contaminating the sealing rail.
Prepare the engine sealing surface following the procedure in WSM Section, 303-00.
Proper usage of the Motorcraft® Metal Surface Prep Wipes is critical.
If possible, allow the new RTV sealant to cure for 4 hours before refilling the engine with oil.
Correctly following the WSM procedures is critical.
Skipping or improperly completing steps may result in repeat oil pan leaks.
APPLICABLE VEHICLES
2018 TRUCK: B8 U553N EXPEDITION
NOTE:  This is very similar to what has been happening with the 2015+ Edge, and the move to plastic oil pans.
SSM 47365 – 2018 F-150/Navigator/Expedition – Equipped With 3.5L EcoBoost – Diagnostic Trouble Code(s) DTC P0365 And/Or P0369
Some 2018 F150, Navigator and Expedition vehicles equipped with 3.5L EcoBoost engine may experience malfunction indicator lamp (MIL) illumination with Diagnostic Trouble Code(s) DTC P0365 and/or P0369.
This may be due to low engine oil level, low engine oil pressure or damaged variable camshaft timing (VCT) phasers.
Before performing Powertrain Control and Emissions Diagnostics (PC/ED) Manual diagnostics, inspect the engine oil level and evaluate any abnormal VCT noise conditions.
If engine oil level is correct, and no unusual engine noises are present,proceed with normal PC/ED diagnostics test PPT’DR’.
APPLICABLE VEHICLES
2018 TRUCK: FC P552N F-150
TECHNICAL SERVICE BULLETIN 18-2038 Fuel Filler Door Not Flush With Rear Quarter Panel When Closed – Built On Or Before 8-Dec-2017
30 January 2018
Model:
Ford 2018 Expedition
Lincoln 2018 Navigator
Issue: Some 2018 Expedition/Navigator vehicles built on or before 8-Dec-2017 may exhibit a fuel filler door that is not flush with the rear quarter panel when closed.
Action: Follow the Service Procedure steps to correct the condition.
Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2018 Expedition/Navigator: Remove Material From The Fuel Filler Door Following The Service Procedure (Do Not Use With Any Other Labor Operations) 182038A 0.3
Repair/Claim Coding
Causal Part: 78405A26
Condition Code: 07
Tool Name
Medium Flat Head Screwdriver
Small Rotary Tool
Service Procedure
1. Was the vehicle built on or before 8-Dec-2017?
(1). Yes – proceed to Step 2.
(2). No – this article does not apply. Refer to Workshop Manual (WSM), Section 501-03.
2. Remove the fuel filler door. Refer to WSM, Section 501-03.
3. Using a soft cloth, lay the fuel filler door down so the inside surface is facing up.
4. Locate the raised rectangular area on the inside surface of the fuel filler door. (Figure 1)
Figure 1
fuel filler door
5. Using a small rotary grinding tool or equivalent, grind away the raised material in this area.
6. Remove material until the raised area is flat to the entire adjacent surface.
7. Reinstall fuel filler door to vehicle. Refer to WSM, Section 501-03.
SSM 47406 – 2017-2018 F-150, 2018 Navigator – 3.5L EcoBoost – Built On Or Before 09-Mar-2018 – Oil Consumption
Some 2017-2018 F-150 and 2018 Navigator vehicles equipped with a 3.5L EcoBoost and built on or before 09-Mar-2018 may exhibit excessive oil consumption.
If there are no visible external oil leaks, replace both engine valve covers.
Refer to Workshop Manual, Section 303-01. For claiming, use causal part 6582 and applicable labor operations in Section 6 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2017 – 2018 TRUCK: FC P552N F-150
SSM 47257 – 2018 F-150/Expedition/Navigator/Transit/Explorer – Malfunction Indicator Illuminated (MIL) With Diagnostic Trouble Code (DTC) P025A
Some 2018 F-150, Expedition, Navigator, Transit and Explorer vehicles may exhibit an illuminated MIL with DTC P025A stored in the powertrain control module (PCM).
This may be due to an intermittent or partial disconnect of the harness to the fuel pump driver module (FPDM) connector.
Confirm FPDM connector (F-150 C4336, Expedition/Navigator C433, Transit C433, Explorer C3239) is fully seated priorto performing PC/ED diagnostics or replacing any components.
APPLICABLE VEHICLES
2018 TRUCK: B8 EXPEDITION (U553)
2018 TRUCK: FC P552 F150
2018 TRUCK: B9 NAVIGATOR (U554)
2018 TRUCK: UB EXPLORER
2018 TRUCK: TH TRANSIT V363 FNA
FORD EXPEDITIONS AND LINCOLN NAVIGATORS RECALLED DUE TO SEAT ISSUES.
NOVEMBER 17, 2018 — A Ford Expedition and Lincoln Navigator recall will have dealers inspect and repair problems with the second-row center bench seats in about 38,000 SUVs.  Z
Model year 2018 Ford Expeditions and 2018 Lincoln Navigators may be missing J-channel reinforcement brackets in the second-row center seat track assemblies.
The missing J-channel brackets may allow the seat to move and fail to hold an occupant in a crash. In fact, Ford is telling owners to move the seatbacks to the furthest positions away from the front of the SUVs.
The recalled 2018 Ford Expeditions were manufactured in Kentucky between March 14, 2017, and August 18, 2018. The 2018 Lincoln Navigators were also built in Kentucky, but those SUVs were built between March 31, 2017, and August 18, 2018.
Nearly 35,000 of the recalled Ford Expeditions and Lincoln Navigators are in the U.S., 1,900 SUVs are in Canada and 955 in Mexico.
According to the automaker, no crashes or injuries have been reported due to the defects, but Ford dealers will need to replace the center seat frame assemblies if one or both brackets are missing. ..
SUV customers with questions should call 866-436-7332 and refer to recall number 18S37...
http://m.carcomplaints.com/news/2018/ford-expeditions-lincoln-navigators-recalled.shtml
2019 LINCOLN NAUTILUS RECALL ISSUED FOR 2,700 SUVS
Lincoln SUVs have problems with the hands on/off systems that may not alert drivers of trouble. Z
JANUARY 19, 2019 — A 2019 Lincoln Nautilus recall has been ordered by Ford for nearly 2,700 vehicles equipped with lane-centering assist and adaptive front steering.
The automaker says there are problems with the hands on/off detection systems used to alert drivers to get their hands on the steering wheels.
About 2,276 of the vehicles are located in the U.S. and another 371 are recalled in Canada, and all were built from September 5, 2018, to November 19, 2018.
Customers with questions should call 866-436-7332. Ford's recall number is 19S02
http://m.carcomplaints.com/news/2019/2019-lincoln-nautilus-recall.shtml
