lamrith said:
I can see now how IAT2 can be an issue. Cold this am, <50*, but after a 20min easy drive to work mine was 105* and while I sat there letting the turbos cool a bit before shutdown(habit from old days), I watched the IAT2 climb 2-3* per minute just at idle..
I did notice the temps drop when the car is moving, but staging in staging lines could make for a really hot IAT temp before you get to the line to start. Cooler temps from moving air not hit until you were 1/4 way down track likely and by then you got boost heat coming in hard anyway so too little to late...
Got me wondering... Maybe some sort of supplemental small fan to mount on the Intercooler up front that could even be set to run when the car is off? No air going thru it at that point, but cooler get the metal intercooler, the better and worst case forcing air thru at idle keeping it from just heat soaking?
Since this is a manifold issue, I assume this is good old heat soak from the block to the material of the manifold itself. Were we NA longitudinal blocks we'd be icing between runs to compensate. But since we have all the crap on top we cant ice (and i would not), I gave the fan a thought.. it would help with actual condenser .. but i'm not sure of the payoff, VS the time to tear it all apart to install it. And for the perfectionist in me, unless I could wire it to my dash perfectly I probably would not do it.
Now if there is a kit (that i have not looked for) that would allow me to share the AMPS for the AirCon and power a set of fans on the condenser .. without risk to the wiring .. maybe.
But (in my head) once your moving more than 30mph i imagine that natural air coming in would be enough to cool the charge better than CFM limited fans.. (someone correct me otherwise)
