For anybody trying this, make sure you export your current dashboard so you can pull it up again, it will get wiped when you import.
So from your current dashboard you will hit the little gear in the bottom right hand corner, choose layout settings, then you will have the option to import/export
I just realized It will also load into the current theme being ran so it may look completely different. That may be why it looked all blown up as well so after importing these, switch your theme to bulletproof.
They can appear quite different to other themes so if you load it into one of the translucent themes it will be jacked because it was built based on a non-transparent theme. Changes in bezel thickness of the different themes can also cause edges and grids to not line up just right. If you are like me, that can cause acute OCD.
Make sure you don't make the mistake I did not including the theme it was created with in the filename.
I'm curious to see if this fixes the issue some had.
