New Torque Layout
https://drive.google.com/file/d/0BySleg7SM4KcSUZIRzdpU01vTXM/view?usp=drivesdk dash layout looks same even after reloading and loading default
I can manually add them which im Fine with just need to wait till I'm home next month so I have more than one screen to try and copy yours from https://drive.google.com/file/d/0BySleg7SM4KcdUxLTkdoVDhKVGM/view?usp=drivesdk
Upload it to my Google drive folder or change the file to .zip and then I'll change it back
Google drive didn't recognize the .stg format either.
After you change it back to .stg, put the attached file into root/storage/emulated/0
Open OBDLink and go into the settings menu
Once in settings hit the three dot menu button in the top right corner and select Import Settings.
That file has my layout and the extended pids used.
I can understand the positions being incorrect because the grid coordinates will be different unless you have the exact tablet.
The pids not working leaves me scratching my head though.
I think we goofed not having the ext pids to begin with.
Did you try OBDLink yet?
Their export function allows you more flexibility regarding what is exported.
I'm hoping it saved the gauge templates as well.
If not you will have to save one of each type if you want to modify the current ones.
Make sure you save every time you make an adjustment. You can save them all differently or just overwrite as you tweak them.
HP and Torque haven't worked for me they are supposedly trying to fix that.
I should probably connect and check.
No it would allow me access to put anything there so either in the wrong spot or I have to root to be able
