It's like this, but not nearly as bad14SHOCAR said:Can someone explain the start rattle? Is that where it feels like its misfiring? and you see your rpms dip a bit? I've been trying to chase this issue down with my car.
Thats also what most tech's rely on to further rectify any issues your having,you can refer a TSB as a (safety net). ZSHOdded said:Haven't a clue what drives a TSB generation, but I'd think a combination of complaints, service calls, and engineer-assisted enquiries meeting some statistical significance.
If the oil pump is independently controllable, with or without engine running, maybe the PCM programming can be updated to prime the oil, just like the fuel pump is primed prior to start.66 Galaxie said:I keep wondering how much a pre-oiler may or may not help protect our engines from any start up rattles due to bad cam phasers and/or the tensioner on the timing chain.
Your first video is exactly what mine sound like. Very inconsistent loudness and sometimes doesn't do it at all.markssho said:Thought I would share a startup rattle from my 2010 SHO. Took these videos this summer as it had between 55k-60k miles on it.
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150815_102452538.mp4
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150821_073524526.mp4
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150828_075733945.mp4
On the first link, you can hear it best. I would say that one is around the medium volume level. I've heard it much louder. The other two are not as loud. It really isn't consistent as far as the loudness goes. That's why it is difficult to capture it on video (who's gonna video every startup).
MeanKS said:Guys, so whats the bottom line concerning oil weights and our engines including this possible issue?
5w20 or 30?
I think that the longer the drain interval, the more likely you should move up to 5W30. But if you use the severe duty intervals, 5W20 should be fine. If you then start hearing rattle (even 1-2 seconds long), try switching out to the 5W30, and see if that helps.MeanKS said:Guys, so whats the bottom line concerning oil weights and our engines including this possible issue?
5w20 or 30?
It changed from 5-20 in gen 4.1 to 5-30 in 4.2ajpturbo said:MeanKS said:Guys, so whats the bottom line concerning oil weights and our engines including this possible issue?
5w20 or 30?
Guys,....owners manual lol
FoMoCoSHO said:It changed from 5-20 in gen 4.1 to 5-30 in 4.2ajpturbo said:MeanKS said:Guys, so whats the bottom line concerning oil weights and our engines including this possible issue?
5w20 or 30?
I suspect there was a good reason for the switch.
Even earlier. In the 2011 (Gen 4.1) OM, 5W30 is listed. EB engines across the board use 5W30 now, not 5W20. The NA engines use 5W20.FoMoCoSHO said:It changed from 5-20 in gen 4.1 to 5-30 in 4.2
