I was locally took to the cleaners at Romeo Auto parts. I post pic and get texts of discounts next time. At the arm & a leg price I paid, still worth it IMO.SHOdded said:Nice! BTW, where did you pick up the Amsoil from? Locally or online or ...
Sabtaj1 said:I'm getting a blown up PTU from the local dealer to figure out about drilling a hole and tapping to put a drain plug in the damn thing. If I can do it and make it easy I will do a write up.
It's best/safest to drain and fill multiple times at short intervals with new PTU fluid. But solvents like kerosene can be used as well. Or you could run ATF through it instead. All at your own risk, though. Since the PTU has so little capacity to begin with, you MUST remove any solvent or ATF very thoroughly so as not to change the properties of the PTU fluid that finally goes in.Spenser281 said:Hear me out on this before you say no way, but have any of you tried using a flush solvent in the PTU, and put the vehicle in drive for a minute or two while on jack stands to help break up the sludge? And then remove the solvent/old fluid and replace with new fluid?
gtmorgan23 said:Well I am compiling the stuff to tackle the PTU fluid change. Just trying to decide the best pump to buy.
I will have to use 4 jack stands in the garage so we will see how it goes.
RdGlideGuy said:I started getting the natural gas smell in the cabin a couple of weeks ago. After a close inspection from under the car there is no leaking from the seals and it only looks like it puked out the vent cap. I pulled the plug and used my mityvac to no avail, there was nothing liquid left in the PTU, just thick grease. I put in 11 oz of syn 75/140 and plan and suction it out in a couple of weeks and refill. On my 2010 I only have the metal vent cap and I tried to pry off the cap and put on the 5/16 tubing to extend the vent but it pulled out of the case. How can I add tubing and run the vent up to the master cyl?
