BiGMaC said:4DR's hard work and the gracious offer of FoMoCoSHO made this possible!
No credit to me... I just want one and probably was a bit of nuisance about it. Thanks for putting up with me Mike!
FoMoCoSHO said:Hey Mike, will I have the opportunity to have any enhancements/improvements done to mine while it is there?
Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
"So I was thinking about removing the 3rd Cat on my stock exhaust and installing an electric cutout. I have The 4+ LMS tune and no DPs on the car, I decided to give LMS a call and see if this would affect the tune, they said it would. They recommended the Cat DPS, unfortunately I do not have $799 for the Catted DPs at this time. Has anyone here removed their 3rd cat on their stock exhaust and placed a cutout? And if so what problems (codes, tune, etc), and gains did you receive?"
Thanks for the info
Did you have them made or were they off the shelf ?Night Hawk said:This is my set up from the end of last year. I remove the valves and cap it for over the winter months.
4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
We did an H pipe before the flex pipes on the stock downpipes into a single 3" down turn and put a bolt on cap for it.
Worked well.
Pictures are in my build thread.
Magnaflow 2.5" flanges(Summit), boost actuated 11psi(can be adjusted), 3 hundred change through SPT.SwampRat said:Did you have them made or were they off the shelf ?Night Hawk said:This is my set up from the end of last year. I remove the valves and cap it for over the winter months.
How are they actuated ?
What did they Cost ?
Thanks for the info
Worked well.
Absolutely, pointless without as ecu will limit your output.shogunal said:4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
Worked well.
4DRHTRD did you have a tune on yours at the time you installed the cutouts?
4DRHTRD said:Absolutely, pointless without as ecu will limit your output.shogunal said:4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
Worked well.
Lots of answers in my build thread on my flex take a look there for me then see if you have any questions.shogunal said:4DRHTRD said:Absolutely, pointless without as ecu will limit your output.shogunal said:4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
Worked well.
What Tune were you running? Any side affects?
4DRHTRD said:Lots of answers in my build thread on my flex take a look there for me then see if you have any questions.shogunal said:4DRHTRD said:Absolutely, pointless without as ecu will limit your output.shogunal said:4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
Worked well.
No problem will probably save us a few back and fourthsshogunal said:4DRHTRD said:Lots of answers in my build thread on my flex take a look there for me then see if you have any questions.shogunal said:4DRHTRD said:Absolutely, pointless without as ecu will limit your output.shogunal said:4DRHTRD said:Stock exhaust with my cutout I picked up .2 and 2MPH in the 1/4 mile with back to back runs.shogunal said:I posted this on another thread pertaining to cutouts (Moderator delete please delete where you feel it is necessary). Here is what I posted....
Thanks for the info
Worked well.
Got it. Thank You.
