Good video. Glad you found it. I'll have to look into it on mine. Wonder if that could be part of my issue. Is there any upgrade oil that we can use on our cars? Or should be stick with the ford oil?SHOdded said:For transmissions without a serviceable filter, 30K fluid exchange intervals are recommended:
http://www.youtube.com/watch?v=Nse_z9RmPcQ#ws
For a quick definition:Larrylu said:Anybody point me in the right direction to pick up a little knowledge about cold start and warm up, open loop and closed loop, and how O2 sensors are in play for that warm up period?
I'm looking at redline, royal purple and mobile 1 as a replacement. Do you know how to find out what transmission I have? The manual has specs for 3 different transmissions. No numbers on the fill cap maybe on the Trans case.SHOdded said:I think service interval is key, appropriate for your driving habits. With performance cars, driven in that style, I feel it is better to stick to severe duty intervals rather than "normal". If you do that, the Ford fluids should be just fine, though you can certainly upgrade if you so desire. Full synthetic is preferred pretty much across the board for all the fluids. One addendum: brake fluid is not mentioned at all that I can see in Ford's services, but flushing it regularly would be good too, say, every time you change pads/rotors.
http://www.modularfords.com/threads/58339-Definition-of-Closed-Loop-vs-Open-Loop?p=610557
Bike-related post, but still the basics apply:
http://bikeboy.org/open_closed_loop_efi.html
That's impressive.. hah. Thanks for all the work that had taken. Wonder why LV looks like that so soon... :/SHOdded said:In case you are worried that the Mercon LV is looking dirty:
https://www.youtube.com/watch?v=JUBoXyQ7UDQ
Alternatives to Motorcraft:
http://www.redlineoil.com/product.aspx?product=30704
http://www.amsoil.com/shop/by-product/transmission-fluid/automatic/signature-series-fuel-efficient-synthetic-automatic-transmission-fluid/?code=ATLQT-EA
http://www.amsoil.com/shop/by-product/transmission-fluid/automatic/oe-fuel-efficient-synthetic-automatic-transmission-fluid/?code=OTLQT-EA
http://www.valvoline.com/products/consumer-products/automatic-transmission-products/automatic-transmission-fluid/37
http://www.castrol.com/en_au/australia/products/cars/automatic-transmission-fluids/transmax-dexron.html
Need more?![]()
Except that apparently the 3.5 EB does not follow this same method of control logic, which I'd understood as being universal.Larrylu said:Very interesting and educational. I'm thinking this is playing a part in my ongoing KR spike issue. Thanks again for the tip!
Yes, that is because that is literally how control logic works in every other automobile. It seems wreckless and implausible. I'd never heard of WOT closed loop control, and while I still have yet to verify this claim on my own (lazy, right), there have been several owners here who've confirmed it.Larrylu said:Thanks that's good to know. I was assuming from my general reading/studying up, that if given enough throttle, it would revert to open loop. If that's not the case, IDK. I'm tempted to retire the KR gauge as it takes up a fair chunk of my valuable tablet screen. Trying to figure out what is going on, been driving me crazy for months. I wonder if removing the engine cover (which I did) could promote general engine noise, as it does provide a pretty thick layer of sound deadener.........
