TSS said:Cool. I just PMd you a few questions if you don't mind. I want to do this to my MKS but had not heard any good stories like yours....and you are so close I could drive to the same installer - very excited!
TSS said:How long did it take him to install? Does he want to make some more money on the side? Yours is the first real success story I have heard. Others have the shutting off issue.
Is disabling my key a menu option?SHODYOU said:Ford's remote start is able to keep the car running once you open the doors as long as you know what you are doing...
You have to basically disable MyKey, as this is what causes is to shut off upon opening. The car can't tell what key started it so it doesn't know if its the admin key or a programmed key... it makes you restart it so it can see the key.
Totally disabling MyKey, which I doubt most of us really use anyways, and it works fine.
I have the same issue with my 12 SHO. How do you disable my key so the car does not shut off when opening the doors or trying to drive.crash712us said:Is disabling my key a menu option?SHODYOU said:Ford's remote start is able to keep the car running once you open the doors as long as you know what you are doing...
mval said:donk:
Wish I had know there was 1 like you got. my addition is about the same size & mine besides starting open & locks door & does trunk, but since you have to have ford fob anyway who cares & it's a couple hundred less. You did good as far as I'm concerned. The one thing I know is once you get remote start you won't go back, if their was only a way to get the seats going it would be the max.
mikeV
