Great idea right hereZSHO said:If your issue is the excessive gap,did you try installing the original blade on top of the taller blade for a cleaner look.
That will work, but if you have a Menard's around they sell the same stuff with an adhesive rubber strip that I found to be very helpful when installing.BBOX said:So my Airaid is showing up on Thursday. Would anyone have any spare Reflectix/shielding or whatever you're using to upgrade the seal that you wouldn't mind parting with? I found the Reflectix on Home Depot's website but the smallest roll is 25 feet which I figure about 23 I'm gonna have no use for. The foam that Shoboat has listed in the how-to link doesn't seem to be available in the US which is kind of odd to me, but whatever, so I'm looking for that or the insulation that SHOnUup, looks like this: http://www.homedepot.com/p/Everbilt-1-in-x-6-ft-Foam-Pipe-Insulation-ORP11812/204760805?N=5yc1vZbuy9Z402 would do the trick for me?
Anyways, I figured I'd ask before I bought anything so let me know.
I also have some of the insulation left over you could use.BBOX said:So my Airaid is showing up on Thursday. Would anyone have any spare Reflectix/shielding or whatever you're using to upgrade the seal that you wouldn't mind parting with? I found the Reflectix on Home Depot's website but the smallest roll is 25 feet which I figure about 23 I'm gonna have no use for. The foam that Shoboat has listed in the how-to link doesn't seem to be available in the US which is kind of odd to me, but whatever, so I'm looking for that or the insulation that SHOnUup, looks like this: http://www.homedepot.com/p/Everbilt-1-in-x-6-ft-Foam-Pipe-Insulation-ORP11812/204760805?N=5yc1vZbuy9Z402 would do the trick for me?
Looks nice...i did wrap the intake piping with the stuff I had, doesn't look so hot (barely see it though) after a few that's for sure.ZSHO said:http://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K/ref=sr_1_1?s=automotive&ie=UTF8&qid=1413335457&sr=1-1&keywords=heat+insulation Found this and think it would be very productive in sealing up the Airaid box,more neatly even for the intake piping.
Airbornemaikai said:Yea the roll of reflectix tape I got was 25ft as well, smallest I could find. It's only like a 1/2 wide though so you'd be surprised how much you can use to cover it really well. That other pipe insulation is only like $2.50 for a 3 pack and you only need one. I ended up finding the foam I used at lowes because home depot didn't have any (you're right that expanding one isn't sold in the US for whatever reason).
boostedbull said:You guys are going to a lot of work to make your aftermarket intake function like the stock one.
Don't hate me. Had to say it.
SHOnUup said:I also have some of the insulation left over you could use.BBOX said:So my Airaid is showing up on Thursday. Would anyone have any spare Reflectix/shielding or whatever you're using to upgrade the seal that you wouldn't mind parting with? I found the Reflectix on Home Depot's website but the smallest roll is 25 feet which I figure about 23 I'm gonna have no use for. The foam that Shoboat has listed in the how-to link doesn't seem to be available in the US which is kind of odd to me, but whatever, so I'm looking for that or the insulation that SHOnUup, looks like this: http://www.homedepot.com/p/Everbilt-1-in-x-6-ft-Foam-Pipe-Insulation-ORP11812/204760805?N=5yc1vZbuy9Z402 would do the trick for me?
Rich
While I agree it is promising, the results are within the normal variances i see on track nights. (rip Kil-kare)BBOX said:boostedbull said:You guys are going to a lot of work to make your aftermarket intake function like the stock one.
Not really, since these modifications have shown improvements over the stock air box. It's a small sample size and it's not by any means an ideal solution, but sometimes you gotta make chicken salad out of chicken ****.
Gotta agree.... Put your ride on the dyno with stock intake and filter.... Then completely remove the filter and box from the intake "saxophone".... Mine showed no difference in performance in back to back pulls.... Doubt if others will..... But if you want eye candy and turbo spooling sound go for it! .... But make the aesthetics good.FoMoCoSHO said:While I agree it is promising, the results are within the normal variances i see on track nights. (rip Kil-kare)BBOX said:boostedbull said:You guys are going to a lot of work to make your aftermarket intake function like the stock one.
bee615 said:Instead of using the silver HVAC type insulation, I am going to line my Airaid box inside and out with Hushmat Ultra. It's supposed to decrease heat transfer by at least 40% and its gloss black which will look a little better. Also purchased the taller weatherstripping for an additional $10, hopefully it makes good contact with the MKS hood.
