Wastegate ordered.. picking up tomrrow.. will stop by the local parts place for the "T", tubing, Pipe, sleeve on the way.... Thanks AJPTurbo!!!
Yes it's called the noise maker eliminator pipe on my site, just need to try and secure a WG aluminum weldable mountsholxgt said:Loving this development!
Can the hot pipe from just intercooler to throttle body with wastegage provision be an option?
So the tial comes with a v clamp flange, it suppose to come with two... I am picking it up tomorrow, if you want, I can send you one of the flanges to model after?EcoPowerParts said:Yes it's called the noise maker eliminator pipe on my site, just need to try and secure a WG aluminum weldable mountsholxgt said:Loving this development!
StealBlueSho said:So the tial comes with a v clamp flange, it suppose to come with two... I am picking it up tomorrow, if you want, I can send you one of the flanges to model after?EcoPowerParts said:Yes it's called the noise maker eliminator pipe on my site, just need to try and secure a WG aluminum weldable mountsholxgt said:Loving this development!
If you want it done in stainless I can do it, not as pretty but also $150 MORE just for that one pipe so figure around $700 with WG and pipe. Not worth it.AJP turbo said:StealBlueSho said:So the tial comes with a v clamp flange, it suppose to come with two... I am picking it up tomorrow, if you want, I can send you one of the flanges to model after?EcoPowerParts said:Yes it's called the noise maker eliminator pipe on my site, just need to try and secure a WG aluminum weldable mountsholxgt said:Loving this development!
Problem is the ones that come with the wastegate are steel...eco power parts uses an aluminum pipe, thats why i mentioned just using a steel inlet tube to theottle body
Mike why dont you like the steel?
StealBlueSho said:Installed today... Preliminary datalogging looks promising! Will update after tune is loaded
ZSHO said:I purchased mine through Full-Race and IMHO great overall company and customer service and Corell at corell@full-race.com was very helpful in answering all my questions and here's the link and[spring rate] as AJP mentioned above. Z http://www.full-race.com/store/blow-off-valves/tial-bov-spring.html :thumb:
True....just wanted to throw in my positive experience with Full race and especially there customer support and pretty sure the collective minds will come up with a viable solution. ZAJP turbo said:ZSHO said:I purchased mine through Full-Race and IMHO great overall company and customer service and Corell at corell@full-race.com was very helpful in answering all my questions and here's the link and[spring rate] as AJP mentioned above. Z http://www.full-race.com/store/blow-off-valves/tial-bov-spring.html :thumb:
Z the fundamental operating principle is completely different....there may be a few springs available but im not even sure which spring you would choose....bov use vacuum to act on the diaphragm to open the valve.....at wot there is no vacuum so you need a device that will open on boost which is exactly what a wastegate does....once a desired pressure is reached then the gate opens....bov's dont work that way at all.
