Could I use these parts to craft this for my car since there are no other options available yet?
https://www.amazon.com/Turbo-Valve-Flange-Adapter-Type-S/dp/B00U4A3GGG/ref=sr_1_21?ie=UTF8&qid=1478420246&sr=8-21&keywords=bov+t+pipe
https://www.amazon.com/Bolt-External-Exhaust-Manifold-Wastegate/dp/B00N1B62G6/ref=pd_sbs_263_2?_encoding=UTF8&psc=1&refRID=Z8G2B2QHSSNKD6P4SSB0
I'd have to cut my intake hope to splice the t-pipe in, but it *shouls* work, shouldn't it? The 2.5" t-pipe is just for an example. I have to go measure the hose to make sure that's the right size.
I wouldn't use that wastegate on the turbo, but it should be fine in this application, right? Other than not being able to build boost, I can't imagine anything catastrophic happening even if the cheap WG fails. Also, since that WG only comes with 2 springs, can I use a boost controller to fine tune it?
Obviously this has to wait until SCT decides I'm allowed to get a tune...
