ecoboostsho
Hmmm...I don't remember seeing Oil Pressure as an option anywhere in my existing scantool. If it is I could certainly figure it out. Let me see if it's there and I will get back to you.
Thanks ecoboostsho. That tweak to the formula worked like a charm. Now I'm showing a steady progression of IAT's warming as they wend their way through the hot plumbing.ecoboostsho said:Larry. CAC is in degrees C. Multiply by 1.8 +32
I've posted pics but never videos. Do I use the same procedure to post a video?SHOdded said:A video of your new setup would be awesome, Larry! Hint, hint![]()
Larrylu said:I've posted pics but never videos. Do I use the same procedure to post a video?SHOdded said:A video of your new setup would be awesome, Larry! Hint, hint![]()
ecoboostsho said:It doesn't look like oil pressure is available...
6 Hours? Holy crap. I know that with previous GM's I had, just changing the pressure caused the sensor to "ping" the ECU. for example. Let out 10 psi and add it back in. I will check with Forscan to see if this is the case with Ford.ecoboostsho said:I am sort of making progress on the tire pressure. I can see the PIDs....left rear is 224141 but I get a pretty crazy response from the car that is going to take some time to decode. I will probably have to let the air out of one of the tires and see how the computer responds but apparently it can take up to 6 hours for the sensors to 'ping' the ECU and update the value. May take awhile...
On mine it just takes a few seconds of driving to clear the light once it has set. So I'm pretty sure its looking every keycycle.ecoboostsho said:I am sort of making progress on the tire pressure. I can see the PIDs....left rear is 224141 but I get a pretty crazy response from the car that is going to take some time to decode. I will probably have to let the air out of one of the tires and see how the computer responds but apparently it can take up to 6 hours for the sensors to 'ping' the ECU and update the value. May take awhile...
