jman said:Did you do the compression test?
SHOdded said:Best of luck!
TopherSho said:SHOdded said:Best of luck!
I am so confused. This car makes no sense ... all three bank1 injectors are leaking. how? ... all at one time INSTANTLY?? makes zero sense. compression test came out fine.. injector test hard failed on 1,3 and 5 was meh.
I give up on trying to understand ... done-zo..baffled...utterly baffled...
jman said:I'll take that outcome 100 times before a blown head gasket or damaged valve...
MiWiAu said:TopherSho said:SHOdded said:Best of luck!
Just curious, how many miles are you at? And do you do any regular fuel system cleaning?
After my stuck injector (around 34k miles maybe?), I ran 2 stroke oil in every tank for 2 years (probably close to 40k miles). Never had a repeat, but stopped with the mix because it was too much of a pain for my wife when we swapped vehicles. I just ran a bottle of Amsoil PI through the last tank. Don’t really notice a difference but hoped it might keep the injectors clean. Kinda paranoid now after first failure around 34k miles. Still not sure if the stuff is snake oil or what, but it makes me feel like I’m doing something preventative.
TopherSho said:im at 70k now
lamrith said:Have to wonder if that had more to do with your plug fouling than the plug themselves. I have not heard of anyone else having issues with colder plugs, I know I have not and I live farther north than you do by a few hundred miles. Could be the fouling was a warning sign of the failing injectors that only showed as an issue when you put colder plugs in?
SHOdded said:Injectors do fail.
1, 3 are bank 1, 5 is bank 2.
Most people find only 1 bank failing. Make sure they replace ALL 6.
TopherSho said:SHOdded said:Injectors do fail.
Yes sir, that was my reply.
i must have looked at the wrong v6 layout.. its all three back plugs near the fire wall
