ZSHO said:Damn! Sorry to hear TopherSho and quite speechless @ the moment. Z![]()
802SHO said:Very very sorry to hear the bad news Tophersho. Speechless is right.
MiWiAu said:Damn dude, sorry to hear that.![]()
What exactly will you spend 14 grand on that is even close to your uber low mileage SHO in luxury and performance?TopherSho said:miss-diagnosis. blew#2 rings straight into the pan. Mechanic thinks the injector failed at load, filled the cylinder, phyciscs did the rest.
well so much for this car. im not putting 7k$ into a car i owe 7k$ on still. i will just let it rot in the driveway.
FoMoCoSHO said:What exactly will you spend 14 grand on that is even close to your uber low mileage SHO in luxury and performance?TopherSho said:miss-diagnosis. blew#2 rings straight into the pan. Mechanic thinks the injector failed at load, filled the cylinder, phyciscs did the rest.
Edit- I see the wife stepped in, lol.
You verify the reman does not have new water pump? Just seems that water pump is part of the timing chain setup, so I would think for it to be a longblock with timing gear the pump would be remanned also? I could be wrong, but I would definitely check that before throwing $ at a new pump. Make sure they replace all the injectors and do not just throw the working old ones back in when they put it all together. Some dealers will not do that by default and then you eat another motor in 5k miles...TopherSho said:FoMoCoSHO said:What exactly will you spend 14 grand on that is even close to your uber low mileage SHO in luxury and performance?TopherSho said:miss-diagnosis. blew#2 rings straight into the pan. Mechanic thinks the injector failed at load, filled the cylinder, phyciscs did the rest.
Not only did she step in she opted for a new remanned block out of washington with a 3 year / 100k .. So i guess were doing that? I am shocked honestly. I was ready to let it all go.. but i think shes too used to having two drivable cars. She still shot down getting a model-3p though
So were about 3 weeks out .. to be continued.
The block and heads and all will be new, I have also ordered new water pump, and rubber bits and hot pipes.
so dumb question .. I'm REALLY happy with the Brad-tune i had. And the new block and setup will be 'newer' and prone to LESS pre-igniton and support better timing with less carbon in the cylinders. do i REALLY need to rebuild my tune from scratch?
