Here is info on how to make vehicle changes using forscan.
Mobile application is ONLY a data logger must use a computer to make changes.
Download link http://forscan.org/download.html
https://youtu.be/0I2KEEMPSt8
Info about getting license to make changes.
without license it's just diagnostic logging software.
http://forscan.org/forum/viewtopic.php?f=5&t=836
Code edits not in forscan yet.
Remove double honk
bdycm
726-16-01 0211 57 as built
726-16-01 0201 47
AWD distribution driver gauge
ipc
720-01-02 8AFC-4CF0-3F2B asbuilt
720-01-02 BAFC-4CF0-3F5B
Enable Engine Hour Display
720-01-02 88FC 40F0 3D1B to
720-01-02 88FC 40F3 3D1B
Nav on IPC:
Before (compass on IPC)
720-01-02 BAFC 40F3 3F52
After (nav on IPC)
720-01-02 BAF8 40F3 3F4E
Turn off amp and have clean preout from radio from fusion forum
http://www.2gfusions.net/showthread.php?tid=3704
Ford fusion write up for FORScan
http://www.2gfusions.net/showthread.php?tid=4573
Change factory splash screen.
http://www.fiestastforum.com/forum/showthread.php?t=11920 page 5
https://drive.google.com/folderview?id=0BySleg7SM4KcSzVYeF9ueGlKWVE
http://forscan.org/forum/viewtopic.php?f=5&t=2331
http://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/index540/
Online updated spreadsheet of what you can change from f150 forum.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#gid=815852466
Mustang spreadsheet
https://docs.google.com/spreadsheets/d/1-gytuV9qPfxvLLcFBIl6nt9h5MGW-NWEPc04cN-ro60/htmlview#gid=0
Taurus spreadsheet-currently down trying to find something similar
https://onedrive.live.com/view.aspx?resid=6DF661C7B798C246!36209&ithint=file%2cxlsx&app=Excel&authkey=!AOW_-cRixqVIJWM
Good forscan forum for the Taurus
https://forscan.org/forum/viewtopic.php?f=5&t=2662&hilit=2015+ford+taurus+awd
Flex spreadsheet
https://docs.google.com/spreadsheets/d/1qe8PznI_XvEb5NPaRCN5OBXpcdrIvx6qvenWbHRtRA8/edit?usp=sharing
Flex forum
https://www.fordflex.net/forums/viewtopic.php?f=3&t=17209
Explorer forum
http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/
Explorer spreed sheet
Sync2 https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/htmlview#gid=0
Sync3
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2016-2018_Explorers
I recommend
http://www.obdlink.com/mxwf/
Or
http://www.obdlink.com/mxbt/
Go WiFi if you have iPhone
Others say kiwis are a good cheap option I've used the first kiwi it was fine but know it couldn't do hi and low can speed.
https://www.plxdevices.com/category-s/195.htm
Kiwi3 it's has poor reviews on the play store.
Here is some information about reading hex for odometer.
https://youtu.be/XKXn_EcZblY
Remove double honk
bdycm
726-16-01 0201 47
ipc
Nav on IPC:
After (nav on IPC)
Mustang spreadsheet
Flex spreadsheet
Flex forum
Explorer forum
Sync3
I recommend
Or
