Fuel Pump Module Recall
Here is the update on the procedure for the recall and as a courtesy the dealer installed a high performance module.LOL.with part number AA8Z-9D370-D .Work order below :).  Z
    https://drive.google.com/file/d/0B8JUL90DXgdib0hheEtpQVJtY3JLTEhkRlZVeHlaSlFkYnU0/view?usp=sharing
does the 13 mks ecoboost get this recall. I went to get tires balanced at a horrible lincoln dealer and they said their were none . I didnt believe them.
Yup,did you receive a recall letter in the mail.?  Z.  https://drive.google.com/file/d/0B8JUL90DXgdiaWxocmdhUnEteTdQbmdTbDJzU3BKLXpFZzQw/view
I would report that dealer to Ford big time. This recall is a major safety item and if they told you no recall on your mks and there is that's a major flaw in that dealership..
I just picked up my SHO and the dealer said the parts were on back order and I had to sign a waiver that the recall was still open and Ford with notify me when parts are available. Is this true?
Yes that is technically true.  They have parts but are supposed to be saving them for individuals that actually have the module fail.  Some of us have been able to convince our dealers to replace them proactively but it's at their discretion I believe.
If you look at page 3 pertaining to [Stock vehicles] they should of corrected the issue prior to delivery knowing the fact a major safety recall is in effect.IDK  Z    https://drive.google.com/file/d/0B8JUL90DXgdiaWxocmdhUnEteTdQbmdTbDJzU3BKLXpFZzQw/view
I just received the letter today saying parts are available. I called my local dealership on Tuesday (29 NOV) but they said parts weren't available and had to be ordered.
I took a picture of the relay for my 2014 SHO, and it looks nothing like the one in the recall PDF that ZSHO posted. What I assume is the supplier code ends in -0C, and there aren't any Ford engineering part numbers.
I have an open recall for the license plate lamps, and want to get both done at once. My backup camera also stops working intermittently, but the dealer is probably going to say "problem not reproducible".
I have many pdf's here which one R U referring to? Due post us a pic of that one of kind module of your's. BTW the backup camera probably needs to be calibrated through IDS. Z  https://drive.google.com/file/d/0B8JUL90DXgdib0hheEtpQVJtY3JLTEhkRlZVeHlaSlFkYnU0/view          https://drive.google.com/file/d/0B8JUL90DXgdiWHR0eVhmb3RXNTF1RzM3ZDlCcjN2bEJsMGJN/view
The second PDF is the one I was talking about. Mine does not have any engineering part numbers. The first PDF is interesting. It means the -D relay for about $25 is the updated part.
I thought calibration of the camera is just for the lines? There is a way to calibrate it with FORSCAN on my 2014
Which one? I thought I saw one where you posted the receipt with the -D part number. The catalog shows -B to be the original replacement.
The stock module part number is not visible to the naked eye.....I finally was able to find the part number which ends in 0C  [Number 0 followed by a letter C] right above highlighted in pink which tells me it needs replacing. :).....if it ends in 5F as mentioned earlier it does NOT need replacing.  Z  BTW used a flashlight along with the phones flash to try to capture the part number at an angle.
It can be kind of confusing. The D part number replaced the A which is for the Taurus. However, the B part can be used. According to Ford they are functionally the same.,sorry just hate typing from my phone, LOL .Z
66 Galaxie said:
Another part number is popping up on some of the Flex module replacements. aa8a-9d412-ca
I believe that would be the AA8Z-9D370-B module, so the end of the supplier code has to be checked.
Replacement for the MKS also?  I see the AA part number on EBay
Donor Vehicle Information
This item taken off of:
2012 Lincoln MKS
4 Door Sedan AWD
Engine: 3.5L V6 DOHC 24V
Gas Injected Turbocharged
Twin-Turbo W/ECOBOOST
57k miles
Transmission: 6-Speed Automatic
Exterior Color: Black, Code: UH
Interior Color: Black, Code: FW
Manufactured in USA By Ford Motor Co.
Production Date: 12/2011
VIN: 1LNHL9FT4CG805393
