StealBlueSho said:derfdog15 said:Livernois Motorsports said:polskifacet said:Quick update. Got new tunes from LMS. Problem seemed to be fixed but then the temp dropped to 13f. Same issue had to reflash to 91 octane tune. couple wot pulls seemed ok.
I suggest continued contact with the tuning department in regards to this. Unfortunately we get to a point where battling weather can become a hassle. We never know if we are going to have ten 13 degree days or one day of that. Chasing weather gremlins can lead us down the rabbit hole.
What about the benefits of cold weather tuning though(such as finding limits of the car). If my tuner told me we were going to abandon tuning/not worry about an issue due to weather (especially cold weather - worst case fueling scenarios on the GDI Ecoboosts) I would be pretty upset and look elsewhere. If you can get the car running optimally in the cold, with regards to fuel pressures, boost, etc then you KNOW it can run just as well or better in warmer conditions. ie. there is a little margin left in my fuel at WOT currently, and with 10 degree ambients, so I KNOW my car will run, without any issue in warmer spring/summer weather when it is going down the track.
I don't want to have to mess with running a different tune for winter, or a lower octane tune due to fuel quality issues, or weather. As you said, one day it may be 50 degrees, the next its 20 degrees when I leave for work and there is snow on the ground. I don't have time to load a different tune each day, or worry about doing so.
Derfdog15... depends on what you want right? If you want a tune that is pushing the limits of your cars fuel system to get the maximum amount power, then obviously when there are major temperature changes, that tune will greatly affect how the car performs...
Say you tune it to the ragged edge of your fuel system in the summer, ambient temps are 90F... you take the same tune and you are going to have fuel issues in the winter when it hits 19F...
When Brad tuned my car, I had a winter and summer tune just for that reason. The winter tune had a bit less boost to compensate for the colder more dense air which is harder on the fuel system...
Same thing with Unleashed, when I had Torrie tune my car in the winter, the tune was much milder. Come summer, I asked for a retune and he was able to tune it more aggressively due to the warmer air.
LMS has several different tunes for the SHO as well... and A LOT of guys detune their SHO's using various stages for winter months just for that reason.
If you want an all year around tune that's fine, its just not going to be that most aggressive tune out there. There are a lot of reasons for having multiple tunes for different climates...
In short, before calling out a tuner for a tune that might best perform in milder weather, perhaps there are reasons for that...
I get exactly what you are saying, and for sure will revise whatever tune in the summer for the track, BUT I feel that in this specific instance, where fuel may be the concern, and OP seems a bit annoyed about the issue in the cold, that it would make sense for them to make the tune more cold weather oriented. Just my .02
Livernois Motorsports said:derfdog15 said:Livernois Motorsports said:polskifacet said:Quick update. Got new tunes from LMS. Problem seemed to be fixed but then the temp dropped to 13f. Same issue had to reflash to 91 octane tune. couple wot pulls seemed ok.
It all depends on what you are looking for in a tune. Like you say, the weather can vary quite a bit from day to day, especially in the upper midwest.
A large quantity of our customers run a lower octane tune in the winter to compensate for winter blends and driving conditions. Running a "summer tune" on 93 octane at WOT in 20 degree weather and 3 inches of snow seems like a very rare circumstance. We strive to work with the customer to fit all needs but very rarely will there be an instance where ONE tune fits EVERYONE'S needs. Unfortunately it sounds like we are unable to accommodate your tuning needs, we apologize about that. As for our customers on this thread we will continue to offer the utmost level of support available for all your tuning needs and we hope to solve this issue for you in a timely fashion.
understood, it just seems that the particular customer is wanting to be able to run his 93 tune in the cold, seems the utmost level of customer service would entail working on his tune so that he can run his 93 octane tune in the winter, and possibly offering him some form of 'winter' tune.
Again, I see the benefits completely of tunes for different conditions, heck, pro racers tweak there tunes every time they run at the track to compensate for differences in weather, etc. it just seems in the OPs case that he is annoyed he has to run a 91 octane tune on his tank of 93. LME knows where I stand, but I do hope you guys can get him sorted out. I have seem some pretty nice tunes come from you guys, so it seems a shame he is upset/inconvenienced is all. And more-so seems a bit rude to pass the buck of a tune issue he sees to the weather conditions.
P.S. maybe that new HPFP can sway me to a bit more favorable view of LME as well.
