JimiJak said:This topic has been moved under your vendor threads.
The move is not a slight against you or your company. We appreciate all of the research you are doing, and the time you put into our EB engines, but until evidence of your claims is posted this is purely subjective, not "news".
Your company is not alone. All of the vendors are now being held to a standard of a zero-tolerance policy for unsubstantiated claims. If you are going to make a claim as a vendor, you must also post the scientific findings or empirical data that have lead you to that claim.
Thank you for your understanding and cooperation in moving forward.
-JimiJak
JimiJak said:Tracy,
Thanks for weighing in on this!
In regards to the original post (quoted below) what have your findings been regarding engine failure, specifically referring to broken con rods, in EB engines? Are you finding a correlation to roughly 450WHP being somewhat of a potential breaking point as well?
TIA
All vendors advertising their products must post those threads in their individual vendor areas and is being applied equally to ALL vendors.kinder said:I know that some people here feel that Livernois is being 'targeted' and this, to me does not help.
-JimiJak
You will never get imperial data for this. The sampling is too small. We have people running big power with no problems yet, people with 400+ power with no problems yet, and stock cars with no problems yet.
Livernois has already stated that the failed engines THEY have seen come in were running around that 450+ mark. Is it the tune? Is it the climate? Is it the oil choice? Is it the driver? Is it the parts produced during a certain time frame? There is no way to determine this.
They never said that your engine will fail at 450hp. They said that based on the engines they have seen com in they recommend that as a daily driver 400hp is the highest they suggest. (At least to one client.)
Your comment about empirical data seems more petty than fair. And this type of marginalization may cost us a valued source of information. I mean why should they keep posting if they just get grief for it?
And then you post a question, that does not ask for empirical data, and was answered in the third paragraph.
JimiJak said:Tracy,
TIA
I am not a Livernois client. In fact I will prob never be one as I plan on using the iTSX tuner. I have no problems with challenging vendors to back up their claims when they say their product is better than another. But this is not that. This is an opinion and maybe even a light warning, not a claim. Just like Tuner Boost's claims.
I have no idea who Tuner Boost / Tracey is and while I see merit in Tuner's thinking as to the possible problems in these engines (while looking for solutions) he has no empirical data to support his claims either.
Livernois seems to be the most vocal of the tuners. Torrie responds fast to PM's and emails but I don't see him as vocal on the site. Maybe I just don't read those threads?
In my opinion.![]()
Tuner Boost said:Not really. We see 500 plus and rods holding up. Similar to the GM 3.6L DI engine. Both are strong. What we generally see as far as rod failure is when hydrolock occurs (have never in my career seen and engine experience it as often as the EB, and that is due to the PCV system flaw, not the engine design). Several we have torn down for other reasons seemed to still run great, but we find a bent rod or two and that is not happening from power....it is when the piston cannot compress liquid ingested from upping the boost allowing the mix collected in the CAC to be pushed into the intake manifold. No rod even forged twice as strong can survive that. Something has to give, and rod or piston (or both). The bent rod may last for the life of the engine, but the piston is now behind in timing and never reaches the top of the deck and the quench area will no longer be effective allowing heat build up beyond what the piston can survive with. Quench area is critical so you dont want a piston sitting low in the hole. Empty and clean the CAC, correct the PCV system flaw and trap all of this mix before it can reach the combustion chamber and these motors seem to take 500 plus HP fine and live. 600 and your going to have failures period. May last a while, may not, but you will have reached all limits.
We sent Livernoise a complete Monster System to install and see first hand 2 months ago, but to date they haven't installed it so if we can get them to put aside the strange belief that this oil/water/fuel/sulfuric acid mix is NOT good for the engine, I think you will see them making much more trouble free power in the future. They do know how to make power and build strong engines no question.....just stuck on the PCV system and dont seem to want to even test in fear they will "see the light".
-JimiJak
JimiJak said:Tracy,
TIA
In my opinion.![]()
13-SHO said:My 0.2 on vendors
They are here to help us. I saw this happen on ClubGP and watched vendors disappear because of it. LMS is just showing us what they found and offering a fix. I hope I never have to take them up on new rods and pistons.....
JimiJak said:Kinder,
Thank you for voicing your concerns. I see where you're coming from and think you have a good point. There's just one thing I would like you to consider:
I have in no way asked LMS not to post what they did. I appreciate what they do, and respect their opinion, just as I do Torry's. But it's just that, their opinion. This thread is very valuable, and everyone's opinion counts. The only problem here was that a thread of opinions is not "news" so it was moved to the appropriate category. Just like everyone else's threads have been getting moved lately. Mine included.
I did however take the time to write them a brief description of why it was being moved as to hopefully dismiss speculation of bias.
Also, (no disrespect intended) "empirical" does not mean "absolute, proven, or scientific", data it means; "based on, concerned with, or verifiable by observation or experience rather than theory or pure logic."
The problem wasn't that they hadn't absolutely proven their theory to be accurate, it was that they provided no information explaining how they had reached their conclusion other than; it's not a detonation problem, so it must be rods and hp."
They have since provided a great deal of very appreciated information regarding how they made their determinations.
I'm sorry this ended up so long, but hopefully it provides some different insight to you and others that may feel this way.
Livernois Motorsports said:All of the engines that have had failures that have been sent to us were from the Taurus SHO, not the F-150. We have not seen any failures from the F-150.
black99lightning said:Tuner Boost said:Not really. We see 500 plus and rods holding up. Similar to the GM 3.6L DI engine. Both are strong. What we generally see as far as rod failure is when hydrolock occurs (have never in my career seen and engine experience it as often as the EB, and that is due to the PCV system flaw, not the engine design). Several we have torn down for other reasons seemed to still run great, but we find a bent rod or two and that is not happening from power....it is when the piston cannot compress liquid ingested from upping the boost allowing the mix collected in the CAC to be pushed into the intake manifold. No rod even forged twice as strong can survive that. Something has to give, and rod or piston (or both). The bent rod may last for the life of the engine, but the piston is now behind in timing and never reaches the top of the deck and the quench area will no longer be effective allowing heat build up beyond what the piston can survive with. Quench area is critical so you dont want a piston sitting low in the hole. Empty and clean the CAC, correct the PCV system flaw and trap all of this mix before it can reach the combustion chamber and these motors seem to take 500 plus HP fine and live. 600 and your going to have failures period. May last a while, may not, but you will have reached all limits.
How much fluid has to be ingested into a cylinder to cause hydrolock? I know our PCV/crankcase evac is not the best but if it is allowing that much fluid to get into the combustion chamber wouldn't we see burnoff? Ounces per a revolution? Everybody demands proof from LMS.....
black99lightning said:JimiJak said:Kinder,
Yet you thank Tracy for chiming in?
black99lightning said:Livernois Motorsports said:All of the engines that have had failures that have been sent to us were from the Taurus SHO, not the F-150. We have not seen any failures from the F-150.
you will surely get slammed for this. Of note you must provide empirical evidence of your claims. Year, mileage, VIN #'s, or you're not telling the truth.
BTW, the only reason I still post here is for the drama. It's so much more fun than Smackdown on SVTP. Pretty boring over there really.
JimiJak said:black99lightning said:Tuner Boost said:Not really. We see 500 plus and rods holding up. Similar to the GM 3.6L DI engine. Both are strong. What we generally see as far as rod failure is when hydrolock occurs (have never in my career seen and engine experience it as often as the EB, and that is due to the PCV system flaw, not the engine design). Several we have torn down for other reasons seemed to still run great, but we find a bent rod or two and that is not happening from power....it is when the piston cannot compress liquid ingested from upping the boost allowing the mix collected in the CAC to be pushed into the intake manifold. No rod even forged twice as strong can survive that. Something has to give, and rod or piston (or both). The bent rod may last for the life of the engine, but the piston is now behind in timing and never reaches the top of the deck and the quench area will no longer be effective allowing heat build up beyond what the piston can survive with. Quench area is critical so you dont want a piston sitting low in the hole. Empty and clean the CAC, correct the PCV system flaw and trap all of this mix before it can reach the combustion chamber and these motors seem to take 500 plus HP fine and live. 600 and your going to have failures period. May last a while, may not, but you will have reached all limits.
The issue isn't that the pcv is dumping sludge into the im by the gallon... It's accumulating little by little via back flow into the CAC, then allowing for a potential " gulp " to be taken into a cylinder.
Ummm... Yes!
I'm not sure how many times I have to say it... I appreciate LMS findings and opinion on this stuff... Just as I do Tracy's... But opinions have their place, and shouldn't be talked about like facts. I would love to have even more vendors chime in on what their opinion is for these failures... But I'm not going to consider it proven, factual data, or news without proof... Test results... Or at least some empirical explanation that rules out any other contributing possibility.
Let's be real... If LMS says they're from SHOs, I guess they're from SHOs. Although it does surprise me that with all the longitudinal engines *** had blown up, they haven't seem even one to rebuild. Also surprising that nobody had heard of anybody blowing their first transverse motor yet... And LMS has several in their shop... But I'm not arguing. It just means we don't have the full picture from the ecoboost world yet, and have more to learn.
