Yes, AOS = Air Oil Separator.
There's no mess near the PCV valve or the AOS, but using my homemade mechanic's stethoscope (vacuum hose and an ear) there is definitely a huge hiss coming from around the quick disconnect connector on the PCV valve, and where the PCV valve meets the AOS. That might just be an o-ring, but the valve is cheap enough to just change.
It's silly it's this stupid quick disconnect with some sort of PTFE or similar seal in it and not just a molded rubber hose with a couple clamps. That'd last decades without leaking.
What should I be looking for in terms of EVAP purge cycle? I haven't checked that valve for failure yet, but I understand it's prone to it. I'll do a check while I'm out there picking up from the last couple day's adventures.
SHOdded said:AOS being Air Oil Separator? Is there any grime or oily mess built up in the area around the PCV valve?
You may have to clear the codes and try again next time you restart (after the PCV valve replacement). Then check the EVAP purge cycle and fuel trims.
