TouchOfEvil
EcoBrick Bob said:Wheel hop always scares me. Hard on axles, u-joints and differentials... Only wheel hop I have had with my Flex was recently at the line in first, with Michelin Pilot SS. Wheel hop is always in the front, as rear only handles a max of 150 hp/torque. If you have someone watch your launches, they will see that fronts spin and rears do not. Flex comes with 255-45-20's Goodyear RS-A's for comparison. Never tried them at the strip.
As for wheel hop issues. The cure in Pontiac G8's is to use axles that are different diameters. Expensive but worth it. ($1,000.-$1,700) rear only obviously. Not aware of any axle options for EB drive train.
Mine doesn't hop at launch, it destroys the tires though. They simply can not hang on at full stall launch. If i just stab it and let it flash they hold on tight but that of course would net slower times assuming i can get it to hook up.
The stock tires that came on the Sport are not very good tires.
Hankook Optimo H426 Grand Touring All-Season 255/50/20 reviews only give them a 2.5 out of 5 stars. 440 tread wear A/A but looking at specs and reviews they just don't hook up. Jack of all trades master of none.
I want to put some sticker tires on it but i'm torn between sizes....do i stay in the 255-265 range or go for the gusto and put 275/45/20 on it. Decisions, decisions.
I thought about running the hankooks 4drhrd is running but they are an inch shorter then stock height.
Not sure if i want to drop an inch in tire height ><
