Wow that's a good deal.ZSHO said:Set of Dorman Winter STEEL 18" wheels. Z
Alternate/OEM Part Number(s): DG1Z1015A
GRAND TOTAL $389.56
[Shipping & promo code applied]
Backspacing169 MM
Bolt Pattern Diameter114.3 mm
Bore Diameter63.6 mm
Center Cap IncludedNo
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Load Rating (lbs)1675 Lbs.
Lug Hole Diameter16.5 mm
Lug Hole Quantity5
Offset (mm)51 mm
Bolt Pattern5 x 114.3
Split TypeNo
Tpms CompatibleYes
Valve Stem Diameter11.5 mm
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
https://www.rockauto.com/en/moreinfo.php?pk=10354140&cc=1503823&jsn=644&_nck=Ekt6BqBF1pxfnyh%2FV1qBw9cgGJ6wcwxHC6Nm
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,wheel,wheel,7644
Yes now to find a good deal on center caps.J-Will said:Wow that's a good deal.ZSHO said:Set of Dorman Winter STEEL 18" wheels. Z
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
And meaty DRs.BlueSHO said:Yes now to find a good deal on center caps.J-Will said:Wow that's a good deal.ZSHO said:Set of Dorman Winter STEEL 18" wheels. Z
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
Or Blizzak tires for us with bad winters..J-Will said:And meaty DRs.BlueSHO said:Yes now to find a good deal on center caps.J-Will said:Wow that's a good deal.ZSHO said:Set of Dorman Winter STEEL 18" wheels. Z
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
I'd want a set for my Yukon at that steal. Need to be 22s though.
