Rock Auto Closeout
FYI- Wholesaler Closeout parts available for your vehicle that can probably all ship in the same box, click the (RSS icon) after selecting your vehicle’s engine size (RSS icon) is next to the (engine size) @ (RockAuto catalog) and then click on the (HTML icon) next to "Love a Bargain. Z  :)
Www.rockauto.com
Sweet Deal on TSS- Sensor! Z  :)
MOTORCRAFT DY1241 - AA5Z7M101B
$6.47- ea - SAVE 87%
https://www.rockauto.com/en/moreinfo.php?pk=3422133&cc=1503823&jsn=__GIP__30__
https://www.rockauto.com/RSS/vehiclefeeds.php?carcode=1503823&m=wc&l=en
Set of Dorman Winter STEEL 18" wheels. Z
Alternate/OEM Part Number(s): DG1Z1015A
GRAND TOTAL $389.56
[Shipping & promo code applied]
Backspacing 169 MM
Bolt Pattern Diameter 114.3 mm
Bore Diameter 63.6 mm
Center Cap Included No
Color Black
Dimensions 18 x 8
Grade Type Regular
Load Rating (lbs) 1675 Lbs.
Lug Hole Diameter 16.5 mm
Lug Hole Quantity 5
Offset (mm) 51 mm
Bolt Pattern 5 x 114.3
Split Type No
Tpms Compatible Yes
Valve Stem Diameter 11.5 mm
Diameter 495 mm
Finish Painted
Material Steel
Width 236 mm
https://www.rockauto.com/en/moreinfo.php?pk=10354140&cc=1503823&jsn=644&_nck=Ekt6BqBF1pxfnyh%2FV1qBw9cgGJ6wcwxHC6Nm
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,wheel,wheel,7644
GRAND TOTAL $389.56
Backspacing169 MM
Bolt Pattern Diameter114.3 mm
Bore Diameter63.6 mm
Center Cap IncludedNo
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Load Rating (lbs)1675 Lbs.
Lug Hole Diameter16.5 mm
Lug Hole Quantity5
Offset (mm)51 mm
Bolt Pattern5 x 114.3
Split TypeNo
Tpms CompatibleYes
Valve Stem Diameter11.5 mm
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
Wow that's a good deal.
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
Yes now to find a good deal on center caps.
BlueSHO said:
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
And meaty DRs.
I'd want a set for my Yukon at that steal. Need to be 22s though.
J-Will said:
BlueSHO said:
GRAND TOTAL $389.56
Backspacing169 MM
ColorBlack
Dimensions18 x 8
Grade TypeRegular
Lug Hole Quantity5
Offset (mm)51 mm
Split TypeNo
Tpms CompatibleYes
Diameter495 mm
FinishPainted
MaterialSteel
Width236 mm
And meaty DRs.
Or Blizzak tires for us with bad winters..
