Well, I finally got my Turbosmart BRA installed.
ADAPTER MODIFICATION REQUIRED!!
I don't know if the MAP port is a larger diameter on the F150 vs transverse or if my manifold is just out of tolerance, but the adapter shoulder would NOT fit my MAP port.
I carefully removed the o-ring and decided to use a cheap Harbor Freight file and some emery paper to remove enough material from the shoulder to allow me to install the adapter.
Once the adapter is installed, the engine/beauty cover DOES NOT fit. I'm undecided if I want to get some spacers to allow me to reinstall the cover.
Functionally, there seems to be no effect on MAP readings (see below). I would have preferred that the screw included in the kit had the same type of head (T20 torx) as the OE screw to reduce tools required for change.
SHOdded said:
Looking forward to results, MiWiAu. Probably won't affect the MAP readings, but would like to have field data to bear that out. Good point about the appearance cover. Run nekked!!!
Here is a comparison of baseline (MAP directly mounted to IM) to the Turbosmart Boost Reference Adapter.
You can see, overall the MAP readings averaged 4.2 to 4.7 kPa below TIP.
