derfdog15 said:Once I'm back home today I'll open up that same log and see what hp was at those points.
It'll be interesting to see the shapes of your curves and peak points compared to what you saw on the dyno.
MiWiAu said:Quick update on my Tial spring preload idea. I don't think it's going to work. Tial says the cap threads are M10x1. The M10x1 screws I got are a sloppy fit and would surely tear up the aluminum cap if any sort of spring pressure was applied. Unless I can find a better fitting fastener, I think that idea has been deemed "not feasible".
f8tlSHO said:I have been dialing in the mbc the last day and a half when I was out running errands. This method is not recommended for the set it quickly mindset. I dialed it one way till I got to the point that it closed, dialed it the other way till it opened, I am now in the process of closing it again. Prob doing 1/2 turns each time on the mbc. Have about 20 adjustments under my belt. More to go, just some information for anyone looking to go down this road.
MiWiAu said:derfdog15 said:Once I'm back home today I'll open up that same log and see what hp was at those points.
f8tlSHO said:Ok, I think I am going to tap into the brake booster line instead of the way I have it now. This line comes directly off the intake.![]()
I can't seem to get a consistent result with the wastegate. I changed to the other spring that I have, didn't seem to make much difference. Both springs I have seem to be about the same pressure at the same height when compressed. I think I am going to take them to work and check them on my spring tester.
I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
f8tlSHO said:I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
Sorry not kpa, I meant psi. So like 7psi boost because of the 14.5 atmosphere psi. It's opening way early.AJP turbo said:f8tlSHO said:I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
I'm not sure what you mean by 22 kpa and 18-19 kpa?
I would go by sound...I would say you should hear the noise and air bleeding off at every WOT upshift and maybe a little longer on the 2-3 wot upshift....Because of the intensity of the boost spike on the 2-3 the "whoosh" sound can last well into 3rd.
f8tlSHO said:Sorry not kpa, I meant psi. So like 7psi boost because of the 14.5 atmosphere psi. It's opening way early.AJP turbo said:f8tlSHO said:I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
SHOdded said:Looking forward to results, MiWiAu. Probably won't affect the MAP readings, but would like to have field data to bear that out. Good point about the appearance cover. Run nekked!!!
Yes on the correct line, don't want to sound like an ass, but I completely understand how this mod works. If I close the mbc fully the wastegate will not open. I thought I was getting it dialed in, then this morning the gate is opening about 2psi earlier than yesterday. It's hard to explain my issue through text without writing a small book. Lol. I think I am trying to close too much of a gap in psi with the mbc. May look at buying some different springs. I have the 13psi spring in, even with no mbc it shouldn't open until 13 or right around 13. It's opening around 7 psi..so trying to close that huge gap with the mbc might be too much. Was also thinking about using both springs and cutting the 7 psi spring down to cut back on the spring pressure.StealBlueSho said:f8tlSHO said:Sorry not kpa, I meant psi. So like 7psi boost because of the 14.5 atmosphere psi. It's opening way early.AJP turbo said:f8tlSHO said:I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
Do you have the MBC on the vacuum line going to the wastegate?
If you do, then I would keep tightening the mbc down until you only hear the wastegate opening at the up shifts like Brad said...
If you keeping tightening and nothing changes then you need to check to make sure the MBC is not faulty or if you don't have it on the vacuum line directly off the wastegate move it there..
I don't know if you saw earlier but my reference line right now is about 3" away from the gate, that's why I was thinking about moving it to the brake booster lineAJP turbo said:Im not sure but i think what might be happening is the mbc is either acting like a restrictor pill or a bleed off for the reference and with more and less boost going through the mbc its not giving the gate a linear type of reference?
f8tlSHO said:I don't know if you saw earlier but my reference line right now is about 3" away from the gate, that's why I was thinking about moving it to the brake booster line![]()
f8tlSHO said:Yes on the correct line, don't want to sound like an ass, but I completely understand how this mod works. If I close the mbc fully the wastegate will not open. I thought I was getting it dialed in, then this morning the gate is opening about 2psi earlier than yesterday. It's hard to explain my issue through text without writing a small book. Lol. I think I am trying to close too much of a gap in psi with the mbc. May look at buying some different springs. I have the 13psi spring in, even with no mbc it shouldn't open until 13 or right around 13. It's opening around 7 psi..so trying to close that huge gap with the mbc might be too much. Was also thinking about using both springs and cutting the 7 psi spring down to cut back on the spring pressure.
MiWiAu said:Well, I finally got my Turbosmart BRA installed.
ADAPTER MODIFICATION REQUIRED!!
I don't know if the MAP port is a larger diameter on the F150 vs transverse or if my manifold is just out of tolerance, but the adapter shoulder would NOT fit my MAP port.
I carefully removed the o-ring and decided to use a cheap Harbor Freight file and some emery paper to remove enough material from the shoulder to allow me to install the adapter.
Once the adapter is installed, the engine/beauty cover DOES NOT fit. I'm undecided if I want to get some spacers to allow me to reinstall the cover.
Functionally, there seems to be no effect on MAP readings (see below). I would have preferred that the screw included in the kit had the same type of head (T20 torx) as the OE screw to reduce tools required for change.
Here is a comparison of baseline (MAP directly mounted to IM) to the Turbosmart Boost Reference Adapter.
You can see, overall the MAP readings averaged 4.2 to 4.7 kPa below TIP.
f8tlSHO said:Yes on the correct line, don't want to sound like an ass, but I completely understand how this mod works. If I close the mbc fully the wastegate will not open. I thought I was getting it dialed in, then this morning the gate is opening about 2psi earlier than yesterday. It's hard to explain my issue through text without writing a small book. Lol. I think I am trying to close too much of a gap in psi with the mbc. May look at buying some different springs. I have the 13psi spring in, even with no mbc it shouldn't open until 13 or right around 13. It's opening around 7 psi..so trying to close that huge gap with the mbc might be too much. Was also thinking about using both springs and cutting the 7 psi spring down to cut back on the spring pressure.StealBlueSho said:f8tlSHO said:Sorry not kpa, I meant psi. So like 7psi boost because of the 14.5 atmosphere psi. It's opening way early.AJP turbo said:f8tlSHO said:I had it yesterday opening around 22kpa this morning it was 18-19... maybe I need a heavier spring. I feel like I turn the knob 20 turns and nothing changes, it turns a lot from fully open to fully closed.AJP turbo said:What is making you think you arent getting the proper result?...what are you attempting to hear/see?
f8tlSHO said:Originally I thought I was missing a spring also, but then I found this![]()
With both springs in the gate wouldn't open so it had to have been closer to 20psi. That's why I was thinking about cutting down one spring to create a lower preload pressure which would create a lower opening pressure on the gate
