f8tlSHO said:Ok, the gate did not open at all. I did not have the right spring in the gate. It came with 2 springs, a 7 and a 13. I must not have read instructions thoroughly. It is set for 20psi. I assumed there was supposed to be 3 springs and they shorted me one. Tomorrow is another day, the ground is wet here anyway, car was having trouble getting traction
I saw your logs and could see you were spinning...You had tq reductions from traction control shifting into 3rd....Just for the record I don't like MBC and wish you had a TIAL or turbosmart wastegate...It just adds an element and it makes it seems like this is a complicated mod...But I'll work on it with you!...I'm afraid if I open up the throttle at higher boost that you are running and you have the MBC wrong or in your case they loaded it with a 20 psi spring set you will get boost spikes way over what we should.
