Sinister-CO said:AJP turbo said:Thats why its also retarded when people say that you can get a same result by either doing more spark and less boost or more boost and less spark.....you tune max spark at all boost for a properly tuned car
You might be generalizing a bit here. Some platforms respond better to timing and others to boost. I suppose the ecoboost might fit this bill, but haven't we seen logs where some run more boost with less timing and others more timing with less boost? Sounds like you've found the sweet spot for your car. I doubt many other tuners would put in the time that you have.
You always are running less than mbt spark with pump gas and forced induction...so the fuel is the limitation...so in that case you want as much spark as the fuel will tolerate at any load
I know what you are thinking...but there can be differences in what a persons car/fuel combo can handle from car to car...but all things being equal . Its all about cylinder pressure...so max spark on max boost will always be best until the boost is so high the turbo becomes inefficient
