Polski Meth Kit
ZSHO said:
I used a 3/8" ID 1/4" NPT
1/4" NPTF Female x 3/8" Hose ID Barbed. Z
https://www.amazon.com/Dixon-BF32-Fitting-Nipple-Female/dp/B00835HRYG/ref=pd_sim_328_3?_encoding=UTF8&pd_rd_i=B00835HRYG&pd_rd_r=3ZMW403KR6TFNKPQ631E&pd_rd_w=qUhPN&pd_rd_wg=JQMo1&psc=1&refRID=3ZMW403KR6TFNKPQ631E
Those brass yellow fittings are so much more ugly :P.
The snow pump I have is a monster. Its not even close to fitting like some of the pictures. I had to make an extra plate/braket and shave a bunch of stuff down. should be able to mount it in the morning after 3 hours of fabrication, home Depot and test fitting.
Ace Hardware,moms & pops store's sometimes have a good selection of these hard to find fittings!! Best of luck on the install. Z
install complete! it ever so slightly clears the back of the fog light housing but I didn't want to start over or Swiss cheese the existing one. I could have moved it over a smidge but then it would kink the inlet of the pump.
TopherSho said:
Awesome work,. Any logged tests on runs yet ?
Not spraying. AJP is getting a fine tuned base tune first. I can say IAT2 drops 50 degrees minimum. I'm running less then 10% windshield washer fluid since I diluted what was in there with distilled water and I can see -15 stft. I'll be adding some more water so it doesn't mess with trims.
So your running 95% water as a test?  And you still saw a -15 stft drop?
im not sure about the % but i know i had 1.8 liters of fluid when I started and then tested the system and added about 1/3 gallon of distilled water 1200 ml? so lets say it may have been 50/50? so 10-15% meth?
Interested to see what your fuel pressure and AFRs looks like with this setup...
Figure I'll post my logs. This is the last revision before doing a meth tune. I am spraying windshield washer fluid in these.
So Brad wants more spray! lol car is hungry. I'm going to have to add a second nozzle which is probably half the size of the initial one. Would have had the parts today but waiting on Brads input on what size the second nozzle should be. I have enough knock suppression but the air charge is still a little warm. Ill try and see if i can mount it a bit further away from the throttle body so it has more dwell time before it gets into the combustion cycle.
